Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
Old 05-26-2012, 04:51 PM
CDT's Avatar
CDT
CDT is offline
Unhappy Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
Help - all of a sudden the ABS, BAS and ESP Light went On and the Spoiler Won't Go Down! I read the threads - seems to be a grab bag of problems and the dealer guess until they get it right. I made an appoint to bring my car to Huntington Jeep (in Huntington, NY). Does anyone know if these are are competent with a crossfire? Any suggestions welcome.
Old 05-26-2012, 05:01 PM
Default Re: Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
Try a new battery if you have an old one in the car, or try a buddies battery, it may save you big time money. You just need one that you can hook up, not drive with.
Old 05-26-2012, 05:39 PM
CDT's Avatar
CDT
CDT is offline
Battery charger is hooked up - let's see what happens.
Old 05-26-2012, 05:46 PM
FUBU's Avatar
Change battery. Old one is dead even though you charge it.
Old 05-26-2012, 05:59 PM
CDT's Avatar
CDT
CDT is offline
But the battery was not dead. I was 50 miles into a 300 mile drive when they lights went on. I stopped, read the manual and it was ok to keep driving. So I continued on my way. So issue with the battery, but it's 7 years old.
Old 05-26-2012, 06:13 PM
bluecoupe's Avatar
These cars are very voltage sensitive. A 7 year old battery is begging to be changed. You've been given very good advise or you can take it to the dealer, it's your money.
Old 05-26-2012, 06:16 PM
I just got an '05 and the first thing I did was to get a new battery. The old one seemed perfect but knowing the problems I opted to take no chances.
My spoiler is still up though.
Old 05-26-2012, 06:19 PM
bluecoupe's Avatar
Drop by Dave, I've got a hammer that can fix that!
Old 05-26-2012, 06:24 PM
Mike1118's Avatar
You came here for help. Change the frig'n battery. Or be a hardhead and spend big money.
Old 05-26-2012, 06:46 PM
Mrmiata's Avatar
Sounds like a dealer here.. throw parts at it till it's fixed.. Didn't cure 180's spoiler.. my abs decided to error and erect spoiler one morning.. yes oem white top. Per the manual the system looks for 12 volts for the abs system or faults. Tested mine.. 12.8 volts two hours sitting after a drive... 12.25 volts when ignition is turned on with stereo on (typical starting scenario). So "per the manual" I'd say my battery qualifies as suffecient for abs activation and function.. but she don't work.. another member had "simular" issues the other day.. was the sensor under the consol (yaw sensor I do believe) went bad. So "buy a battery" is not the absolute answer. A few member have had wheel speed sensors go out.. bought 4 of them from mr mopar - johns totalled car.. so eliminated that possibility too.
Old 05-26-2012, 07:20 PM
CDT's Avatar
CDT
CDT is offline
Shoppin' for a battery now.
Old 05-26-2012, 07:26 PM
Mrmiata's Avatar
Let us know if that's the cure.. since you were driving along and out of the blue.. andl if it is the problem I think it could sway me over to dropping $130 on a "lets see"..
Old 05-27-2012, 02:58 PM
CDT's Avatar
CDT
CDT is offline
Was going to buy a battery, but my son (who's an engineer suggested we check voltage) Checked battery - got 12.5V with car off (not started for 24 hours), 12.5 with ignition on and 14.5 with car running. Also compared the "car off" readings to a new battery, they were the same. We're now going to check the wheel sensor connections.
Old 05-27-2012, 06:06 PM
Mrmiata's Avatar
I wish one of these guys that the battery replacement actually cured their problems had done a voltage check before, but I have yet to run across any post that plainly states such.
Old 05-28-2012, 06:21 PM
CDT's Avatar
CDT
CDT is offline
We removed my right front tire and found the sensor. After taking an hour to figure out how to remove the connector (you need to slide the metal clip down and the connector pulls straight out), we did some prelmin. testing and decided we need better testing tools. So we cleaned it up, put it back together and will continue another day. They are so easy to replace I'm considering just buying 4 and putting them on.
I have a question, how do you remove the CAB Module from the HCU? Is there a clip or something like that to release it and to pull it apart? A picture would be great.
Old 05-28-2012, 07:41 PM
Mrmiata's Avatar
interesting reading if you haven't already found this one..Since you were driving along.. wheel speed sensor kinda seems like the issue for you.
https://www.crossfireforum.org/forum...tor-light.html
Since mine reared up when first starting the car - leans me towarads the abs - cab system..
Old 05-28-2012, 08:37 PM
Mike1118's Avatar
No I'm not a dealer. He did say his battery is over 7years old. I'm guessing even if this isn't his problem today it will be tomorrow. I see where a few different members advised the same thing. To be honest, I know very little about these cats. Changing the battery would be my guess for about everything to do with these cars. Oh I just changed my battery the other day. It didn't cure my problem either. So I did the other fix. Black tape over the low water light.
Old 05-28-2012, 09:04 PM
Mrmiata's Avatar
LOL.. seems the battery is the first trigger everyone wants to pull. 7 years old seems to automatically mean it's trash. I do intend to change my OEM in the next couple of months just for grins and peace of mind.. That OEM is going to die one day even though it cranks strong right now. CPS went out and I know I hit the starter at least 15 times and she didn't groan a bit on the battery side of things.
Old 05-28-2012, 10:28 PM
Those OEM Varta batteries are good, Took mine out and replaced it but it was still going strong. It will be 8 years old this November.
Old 05-28-2012, 10:38 PM
Mrmiata's Avatar
I had put a low amp battery in my 94 Chevy truck (occasional usage) .. won't carry a charge for a week with the parasite drain.. but I'm betting the Crossfires OEM will be just fine in it when I do get her a new one .
Quick Reply: Agh! ABS, BAS and ESP Light On and Spoiler Won't Go Down!
