Roof won't open
on
on
Re: Roof wont open
The switch in the yellow circle is what I need. My spring goes up/down great. If you can post please any link or photo of the model, I will say thank you 20 times.
CROSSFIRERUSH (06-13-2020)
on
Re: Roof wont open
I was thinking the same, to cutt the dust boot off, because Mine works but sometimes it stays pushed so the roof doesnt open. I put some wd40 oil and work better but maybe best option is cut that and if doesnt work, cut the wires and put them together.
on
Re: Roof wont open
It'll most likely work. If it doesn't make sure your front bow detent tensor cords are in good shape and holding the front bow in the proper position and high enough to keep the switch released. I personally have never had issues after the dust boot has been removed.
Re: Roof won't open
If anyone discovers the that their "roof open" microswitch located on the passenger side roof rail is defective, I would recommend bypassing it by splicing the wires together. (I did because I couldn't find the replacement switch anywhere) For those who are worried that there is risk of hitting and or holding the button down might engage the hydraulics and potentially damage the pumps should know that the roof has to go through several other procedures (Cycles) before the roof has to go down into the well. IE rear window lifts up, trunk panel raises up, rear window goes back down, THEN the roof starts retracting into the trunk. That's when the risk occurs. That is a loooong time to realize that your roof is still attached to your windshield frame.
Another roof Pro tip. I had window that would not go down and it ended up being the BCM. I ordered a replacement BCM on ebay and it solved the window problem but then the ROOF would not go down Problem solved: If you order a replacement BCM for your roadster MAKE SURE it came off of a convertible!
The following 3 users liked this post by Dpalmer22:
NM_IT_JIM
04-27-2019 01:07 PM
crossfireforum1951
11-15-2018 04:16 PM
gibsonjunkie
05-28-2006 06:17 PM
