Replacing battery
Old Dec 27, 2013 | 03:44 PM
gbono2's Avatar
Default Replacing battery
I noticed the last time we started or '05 XF Roadster the spoiler came up & didn't go down. I did some checking on the battery to find: 1). a badly corroded terminal; & (2). this was the original battery installed at manufacture.
It looks like it's time for a new battery! After installing a new battery, must I do anything else? It seems I remember reading something about turning the wheels full left, full right & then to neutral position w/the first start. I just can't find anything on this site regarding this.
Can anyone tell me? Or did I dream this?
George
Old Dec 27, 2013 | 03:50 PM
Default Re: Replacing battery
Only if the ABS light comes on, and it never has in my car.
Also, you will probably loose the clock display in the radio and I think the clock in the dash will goof up. Other than that, no problem.
Old Dec 27, 2013 | 03:59 PM
gbono2's Avatar
Thanks Pizzaguy!!
Old Dec 27, 2013 | 04:57 PM
harbor's Avatar
Be sure to keep the vent tube and positive terminal cover from your orig Varta battery and transfer them to the replacement.
Old Dec 29, 2013 | 07:49 PM
SmokeyRose's Avatar
I replaced the battery in my 2005 Roadster last summer with an Interstate MTP-48/H6. Other than the clock and radio channels everything worked perfect. Perhaps you where thinking of the pwr steering pump or fluid with the left right thing. With all the electronics in these babies, the battery is critical. Rose
Old Dec 30, 2013 | 04:05 PM
PNA's Avatar
PNA
No, Pizza was correct. The light on the dash may come on (mine did) but if you turn the wheel full left, then full right and then to center it goes off.
Old Dec 30, 2013 | 04:26 PM
Padgett's Avatar
I like AGMs so when I replace will probably get one of (and the link doesn't work) - Sam's Club: Energizer AGM Automotive Battery - Group Size H6 LN3
Old Dec 30, 2013 | 06:28 PM
syfi's Avatar
I like these better. Made by Johnson Controls, the same mfg. for the OEM Vartas!
AutoCraft Gold AGM Battery, Group Size H6, 760 CCA H6-AGM: Choose the best Battery at Advance Auto Parts
Old Dec 30, 2013 | 06:32 PM
I run that battery in just about everything but the crossfire. I went with an interstate H6. But I have had pretty good luck with the autocraft, and Advance Auto have been really good on warranty as well. I wouldn't be afraid to use them. Just didn't for whatever reason. Interstate delivers to our company garage and I bought one off the truck. Right place right time right price....lol
Old Dec 30, 2013 | 06:43 PM
syfi's Avatar
Totally agree with ya Doc. I run the non-AGM Autocraft Golds in both of our Xfires with absolutely no complaints. Got them both with discounts for under $100 each.
Old Dec 30, 2013 | 07:08 PM
Padgett's Avatar
We are talking about essentially the same battery: "Sam’s Club Energizer® and OPTIMA® batteries are supplied by Johnson Controls..."
Old Jan 21, 2014 | 09:29 AM
West Peterson's Avatar
What is the cost of the battery at Sam's? I'm not a member, but a friend is, and they don't tell me what the price is online
Thanks.
Old Jan 21, 2014 | 12:54 PM
Padgett's Avatar
One I would like is n/a in Florida for some reason but similar AGMs are now $137 (were $99 last year - bought two for that).
Old Jan 21, 2014 | 03:59 PM
Thanks. I just bought the Advance Auto battery, which is the same price using a $50 coupon.
Old Jan 21, 2014 | 06:26 PM
syfi's Avatar
Sam's has replaced ALL Energizer batteries with Duracells.
Duracell® Automotive Battery - Group Size 48
Item #: 348116 Price: $103.17
20 amp hour rate:70
BCI Group Size:48
CA at 32 degrees F:895
CCA at 0 degrees F:730
DIN code:H6
Reserve Capacity:120
Volts:12
Core Charge may apply
http://www.samsclub.com/sams/duracel...up%20size%2048
By the way, Duracells are made by East Penn and NOT Johnson Controls. Made In The USA!
Old Jan 22, 2014 | 08:09 AM
Wow. And only $103. Could have saved another $50.
Old Jan 22, 2014 | 08:30 AM
Padgett's Avatar
This one ? AutoCraft Gold AGM Battery, Group Size H6, 760 CCA - apparently my Jeep and the Crossfire use the same battery.
That Sam's club page is only finding Marine Duracell AGMs, my store has smaller ones, will check next time I go there.
Duracell shows SLI48AGM Duracell Procell Platinum AGM Battery H6 650CCA
Any more the only batteries I buy are AGMs. Fortunately they are getting more common but are more expensive than wet cell batteries.
Old Jan 22, 2014 | 08:40 AM
This is the battery I just replaced. This couldn't be the original battery, since my car is 9 years old, but was it an exact OEM replacement?
Old Jan 22, 2014 | 09:00 AM
Padgett's Avatar
I doubt that the original came with handles.
Don't know about MOPAR but Delco replacements always had an odd designator (e.g. R-59) because they were shipped dry.
Repopers did not know that and some owners got mad when I told them their very expensive repo had the wrong part number for an assembly line battery.
Is one of the reasons I quit judging.
Old Jan 22, 2014 | 09:10 AM
Sounds like a case where the messenger was being shot.
The reason I would like to know if this is an OEM exact replacement is because if it is, I'll keep it for future "judging." Otherwise, I'll sell it back to the store for $20.
