mpg
Re: mpg
If Flintshire is in Wales then you can expect one sixth more mpg than the US figures as the gallon is larger there and more costly too.
We used the Imperial gallon in Canada before litres came and I got about the same mpg as per ala_xfire.
on
Re: mpg
Expect about 15 - 20 when tearing thru curves and enjoying the drive, like we did over here last weekend on our "Tail of the Dragon" adventure.
Simply stated, the difference between 6 speed and auto is not enough to matter. But the version you want to drive.
Re: mpg
To "piggyback" on pizzaguy's feedback, I averaged 26.5 mpg over 596.8 miles during the ToD (Tail of the Dragon) event last weekend in the NC mountains. I averaged 27.6 mpg driving up & back, running speeds between 70 & 80 mph. I averaged 24.0 mpg in the mountains, using the AutoStick shifting capabilities, which isn't bad considering all the curves & "twisties" we drove on. If you want to see some longer term results for an AutoStick, see the attached file.
Re: mpg
I have a six speed and driving thru the hills and twistys about 50 mph i have averaged around 32-33 mpg on non ethanol about the same as ala xfire. And it's been consistant as I don't beat the car, I bought it for pleasure. Just my type of traveling in Pa.on the back road 2 lane black tops.
