2005 crossfire limited roadster 22,000 miles
I towed my crossfire behind my motorhome yesterday on my car dolly. Front wheel up on dolly and rear wheels on ground. Key was in ignition and on and car in neutral, spun tires going up on dolly and towed for 100 miles. Took car off of dolly and drove it home. No warning lights on dash and car ran fine except when you start off and give it gas it seems to have a jerk going from first to second gear. also does the same thing when slowing down . Car has never done this before so what did I do to it by towing it? Any ideas would help me greatly? New to the forum so I hope I'm doing this right. Thanks
Automatic or manual trans ?
Not sure what might be wrong but it is not good to tow with the back wheels on the ground unless it's a manual trans
That rule goes for any rear wheel drive automatic transmission vehicle
Yep, most people forget these are not front wheel drive, like most today. Most automatic vehicles should not be towed with wheels down without dropping the driveshaft or adding a transmission oil pump to keep the trans. lubed.
Thanks , know any good transmission guys around Frankfort Ky?
I turned away the wrecker the highway patrol called which arrived after a nearly three hour wait because it was going to tow my car with the rear wheels on the ground. The addtional wait was apparently worth it.
If it turns out the transmission was damaged others will benefit by your having shared this. Thank you and good luck.
The rest of the story, had to replace my transmission damage was internal and mechanic said that it would cost a lot to rebuild the transmission. So I found a used transmission with only fifty thousand miles on it. Bought it and replaced my transmission and car works great.
I'm happy to know ya got it fixed
Sad to find out that the towing damaged the transmission but that was what I was afraid of when reading your original post
CycleVIN
Dec 17, 2016 12:19 AM
performanceisland
Nov 2, 2016 02:14 PM
ron44094
Jul 29, 2016 12:48 PM
