New Member '05 Roadster Limited with just under 20k miles. Info?
Hello my new Crossfire brothers/sisters. So glad to be here!
Just got my parents Crossfire out to my house in Los Angeles from back east...of the 19000 miles on it, I've probably put 10k of those on it..Love This Car in. And now it's mine! My build date on the door says 11/04 on this 05, and my Vin ends in 049153. So I take it this is the 49, 153rd off the Karmann line?
sure would love some help if any members want to fill me in on what they know...how many were made of these models? How many are left? Value?(I'm not getting rid of her).
She's running like a champ, but I also know cam/crank sensors should be replaced before it's a problem...thanks to this forum. Also, my first forum, so apologize in advance.
Re: New Member 05 Roadster Limited with just under 20kmiles. Info?
Almost everything you will need to know is here, Except for how many are left and value. That varies by model, color, condition, mileage and where you and where you live as well as other factors.
I've heard about the RCM fix...will need to find someone in Los Angeles xfire friendly mechanic to get ready for the issue. I haven't heard about a sticky key issue, and don't seem to be having any problem with my ignition. Does there tend to be one?
on
Welcome to the best forum for cars that I have ever been on (and that's quite a few). You'll find almost every quirk/issue/problem on these cars right here. One of the universal bits of advice is NEVER take her to a (stealership) dealership, they will drain your wallet and send you on your way. If you ever need to have work done, usually an independent Benz shop (foreign autos) will be able to help as it has the MB SLK-320 drivetrain. Best to you with this jewel!
RCM might have been the problem my parents were having back east. They thought it was a slow drain on the battery somewhere at the mechanics, because they haven't been driving her much...they'd go for weeks(maybe months without driving, and then *** wouldn't turn on. But if you gave her a jump, she'd continue to turn on fine with frequent driving. Seems to be fine out here though...no problems yet!🤞
Re: New Member '05 Roadster Limited with just under 20k miles. Info?
Not sure, but thankfully hasn't happened since I got her out here to California. Maybe she just wanted to get out of her winter garage and come out here to me.
love this car. Even in LA with. Porsche, MB, BMW, Maserati, etc. all around me...this car looks as current and progressive as anything around me.
just turned 20k miles yesterday!
on
But if the car is sitting for MONTHS at at time, of course it wont start.
Shut the car off, pull out the key, close doors and trunk, pop hood.
Take ground cable off battery, insert ammeter - wait for 90-120 seconds for all modules to hibernate.
If you see more than 60mA (.06 amp) or so, you have more current flowing than there should be.
If you see 55ma (.055amp) or less, it is fine.
If you see ZERO current, you have the meter incorrectly connected or the meter's internal fuse is blown.
BUT, in any case, leaving it for months without a battery tender or a charger on a timer is going to mean a dead battery.
Lucky you! & Welcome!
"Sticky key" I think is caused by a broken part in the ignition switch itself. Ours was replaced & no problem since. Crossfires tend to need a battery that is in good to excellent condition. A "load test" may be the best indicator because batteries slowly self destruct from lack of use or regular charging. I'm no tech but thanks to the forum I've tackled the crank position sensor & "RCM" successfully.
I've read about airbag light issues with those replaced because they had the Takata recall. Look for the correct "heading" to post specific questions. Best Wishes & Enjoy!
onehundred80
03-19-2020 06:01 PM
dwightdmagee
09-06-2009 12:49 PM
