Conv. top wiring diagram
on
Re: Conv. top wiring diagram
It's really a mess. The entire wiring involved in the top includes the top control module, the sensors wired to it, the BCM (which commands the windows to go down), the electric truck lock sensors (not the pneumatic lock, the electric lock) as well as the "Trunk Closed" sensor, which I THINK is wired to the Central locking controller - and that status is passed over teh CAN bus to the top module, perhaps via the BCM but I can't say for sure.
There is a pretty good description of the process in the service manual, but it concentrates on the hydraulic system and leaves out a lot of the other sensors involved.
What ya got happening?
Happy New Year Pizzaguy,
I am still trying to figure out the same problem. Does anyone know what sensor, when putting the top up, tells the pump to stop when it is in the full up position? Mine stops but does not beep. I can still latch the top and the switch light stops flashing. When I unlatch the top, the windows only go down about three inches and stop. If I then push the top down switch the windows go down the rest of the way and the switch light comes on but there is no movement or beeping. If I relatch the top the switch light stays on and I cannot open the trunk until the pressure bleeds off. If I unlatch the top and push the button for top up the pump runs for a brief second and the top moves closed for about 1 second. If I then latch the top the switch light goes out and I can open the trunk. It seems as if the top stops just shy of being fully raised. It doesn't seem to really complete the cycle. I have tried re syncing the top with no different results. I have been manually putting it down and putting it up the normal way.
Any thoughts or suggestions would be appreciated. It has to be a sensor issue. Could it be one on the cylinders? I just can't give up trying to figure this out.
I have this diagram, not much to it but I did not see it in the 2005 Service manual, mind you I never study the roadster too much anyway.
There are five pages of the soft top operation as well.
If you have any questions ask someone who knows, I have no clue.
Mike-in-Orange
02-27-2009 10:54 PM
ryan_ss
01-09-2008 01:04 AM
TSaxMan113
10-22-2004 01:50 PM
