One Headlight is Not Working
Old Sep 9, 2020 | 03:14 PM
HazMatt's Avatar
Default One Headlight is Not Working
I was changing out my headlights and like a ninny i forgot to unhook the battery and turn off the headlights. Attached the High Beam bulb and nothing came on, went on to install the low beam and all lights blinked on and then the low beam bulb stopped working. I thought i blew the bulb but i changed it with one i confirmed was working and nothing. Facing the fron of the vehicle - all lights are functional except for the right side low beam. Any help would be greatly appreciated. Thank in advance.
Old Sep 9, 2020 | 04:44 PM
Default Re: One Headlight is Not Working
Try the fuse.
Old Sep 9, 2020 | 04:45 PM
zip439's Avatar
Check the fuses in the side of the dash (drivers side): back off the two plastic screws. There should be a card in there that indicates the fuse circuit.
Old Sep 16, 2020 | 10:42 AM
HazMatt's Avatar
Try the fuse.
BINGO! I thought of that but didn't believe there would be a single fuse for each light - I was wrong. Thank you so very much!
Chiver79
Dec 14, 2018 09:18 AM
OldSalt
Mar 18, 2018 12:23 PM
nickwe21
Feb 18, 2018 12:59 PM
Blackout317
Oct 20, 2017 09:57 PM
crossfire#2
Jan 18, 2013 09:38 AM
