Hydraulic leak on roadster
Old Nov 25, 2020 | 10:06 AM
tdr1300's Avatar
Default Hydraulic leak on roadster
I have to refill my hydraulic fluid canister in the trunk several times a year. The only place that I can see a leak is in that tube behind the passenger rear wheel, nothing in the trunk space that I can see. I tried tracing the rubber tube up over the wheel well but I loose site somewhere behind the plate that covers the gas tank.does anyone have any suggestions as to how I can determine the source of the leak?
Tom R
Old Nov 25, 2020 | 01:00 PM
CROSSFIRERUSH's Avatar
Default Re: Hydraulic leak on roadster
Watch this video from Top Hydraulics. Klaus Witte KNOWS these convertible Crossfire hydraulics. Do a Google search to get their website.
I replaced all my cylinders through them. Having the new to install as you remove the old eliminates the “now how did this go in?”. Turn around was a week to 10 days.
Good luck! This WILL permanently fix your loss of fluid.
Regards,
Old Nov 25, 2020 | 01:27 PM
There is a tube that drains the gasoline filler cavity. And there MIGHT be one that drains the fender well or other area.
You sure it's coming out of that tube? Or just close to it?
chturner
Jul 24, 2015 04:47 PM
babiehop
Feb 21, 2012 10:56 AM
Holycrap
May 23, 2011 11:34 PM
AllEuro
Nov 15, 2009 11:23 PM
crossfiresrt6
Dec 12, 2008 02:29 PM
