Lost - hydraulic pump reservoir plug. Replacement?
I have a 2005 Xfire roadster. I Noticed that the hydraulic fluid in the pump reservoir (in the trunk, driver side) was below minimum.
I purchased the fluid and, as I was unscrewing the drain plug, I lost it down into the fender well. Can’t see it. Can’t fit a hand down there. Tried fishing with. Magnet - no luck. Can anyone tell me where to get a replacement? Or what I can use as a replacement? https://cimg8.ibsrv.net/gimg/www.cro...ec090faf4.jpeg |
Re: Lost - hydraulic pump reservoir plug. Replacement?
It is brass so no luck with a magnet. I'm sure it is metric but have no idea on the size or thread pattern.
Fairly easy to remove pump. Then you can find the plug. Use a cork to keep the fluid in. Disconnect the cylinder from the top, remove 3 10mm? nuts, and it will come up enough to get your hands down into the wheel well.
I have an extra pump so I'll look at the plug to verify size and thread pattern tomorrow. |
Originally Posted by Shamrock
(Post 950730)
Originally Posted by vaboca
(Post 950731)
thank you. I’ll try to remove the pump tomorrow.
The screw has a hex head and a washer underneath the head. Put reservoir pump in search and there is a picture of the reservoir with the screw in place. Search is your friend. |
It was NOT too difficult to remove the entire pump assembly. There is a great video that helped a lot. (link:
Once the pump and assembly was removed - easy to reach into the fender well and locate the (dropped) drain plug. I would recommend being careful not to drop the drain plug - save yourself some trouble. |
