Why the SRT-6 didn't get a stick.
Message Deleted
Re: Why the SRT-6 didn't get a stick.
But they shipped more X-fire's here, and probably a bunch more than that were MB cars...
I think it had to do more with DCX's hating of manual transmissions and warranty work than anything else. Look at what they did to the SRT4 guys, they put out a specific book on mods done to the cars and what to look for, to their service techs. |
I think it had to do more with DCX's hating of manual transmissions and warranty work than anything else. Look at what they did to the SRT4 guys, they put out a specific book on mods done to the cars and what to look for, to their service techs. Slim |
Message Deleted
The 6 speed manual was not durable enough for prolonged use on the supercharged M112 engine, hence AMG opted to utilize the bullet-proof 5 speed automatic transmission instead. A little factoid: The SLK32/SRT-6 shares the same exact transmission with the SLR.
A little factoid: The SLK32/SRT-6 shares the same exact transmission with the SLR. |
This all of course begs the question: Is there an off the shelf Mercedes manual transmission with the correct hole pattern, mounting locations, OAL & compatibility to work with an SRT-6?
What would such a swap entail? Would you need to also get your hands on a new ECU to work with a manual, or is the transmission's controller separate from the motor's? (I spoke too soon before having ruled myself out of the SRT-6 chase. This thread has me thinking it might be worth contacting a dismantler/recycler in the UK). ;) |
wallpaper XC 90 sport pics
---------- SLR TRANSMISSION The Mercedes-Benz five-speed automatic transmission and rear final-drive unit, already used successfully in several high-performance models, have been further modified to handle the high torque of the SLR engine. In addition to beefing up the gear housings and torque converter, gears in the center and rear planetary sets have been widened by five millimeters (about 0.2 inches), and the front planetary gears are two millimeters wider. While the wider gear teeth are stronger, this also makes room for larger bearings. What’s more, the hydraulic clutches that drive and lock the planetary sets in each gear range operate at higher pressures. The transmission oil cooler is larger than on other Mercedes-Benz high-performance models, and a separate oil cooler just for the rear differential/final drive unit is mounted under the trunk floor. Air flows through this cooler from a triangular NACA duct in the otherwise flat underside of the car and exits through a grill between the back-up lights. A New Level of SpeedShift The Mercedes-AMG Speedshift system offers even more features in the new SLR. A knob on the left side of the center console offers a choice of three settings: “Comfort,” “Sport” or “Manual,” and each setting is identified in the instrument cluster display by the letter “C,” “S” or “M.” While the two automatic shift programs are similar, “Sport” provides higher-rpm shift points and crisper shifts. In the “Manual” setting, the driver can shift either with buttons on the steering wheel or by using the side-to-side Touchshift feature on the shift lever. Within the “Manual” setting, another knob on the right side of the console can select any one of three modes of progressively sportier shifting: Stage I – “Sport” Stage II – “SuperSport” Stage III – “Race” In the sequence shown here, the shift response and transmission shifting speed become increasingly shorter. |
5 Attachment(s)
The first photo highlights the Renntech link to the 400HP SRT-6 engine. The second photo highlights the fact that the car is a manual. The third photo highlights the possibility that the actual car is a base or limited model (note speedo MPH).
Would you need to also get your hands on a new ECU to work with a manual, or is the transmission's controller separate from the motor's? |
Originally Posted by msheredy
See the attached photos of Mopar's Crossfire drifter.
The first photo highlights the Renntech link to the 400 HP SRT-6 engine. The second photo highlights the fact that the car is a manual. The third photo highlights the possibility that the actual car is a base or limited model (note speedo MPH).If only Chrysler’s Skunkworks would reveal some of their secrets and that body kit! |
Originally Posted by HDDP
There were no secrets, it was "ALL SHOW AND NO GO" for SEMA a few years ago...
Why are you so jaded???
If you don't believe me, then I would suggest you contact the head of Crossfire Operations for the former DCX and let him tell you directly... They could not even get engine specs for the car from MB until I started rattling cages to get classification for SCCA in 2005... If you doubt this as well... Contact the current president of SCCA, Jim Julow, who happens to be a former DCX executive... |
... Fact is fact...
| All times are GMT -4. The time now is 08:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
