Help!!! beeping when i hit 85
Old Nov 9, 2007 | 03:58 PM
jonnyangel04's Avatar
Default Help!!! beeping when i hit 85
My car chime starts to beep as soon as i go over 85. IT doesnt matter if I go faster only stops when I slow down and bring it back under 85. I guy at the dealer thought it might have something to do with the weather being 45 degrees today and it was just a warning that the conditions could be bad over 85. I dont think that is the case although ther is no codes and no errors. I know people have had this problem with there wing deployment but this cant be the case on the SRT6. Im so mad I havent been up to 85 in awhile so i probably just never herd it. ANYONE HAVE ANY IDEA WHAT IT MIGHT BE its freaking me out there isnt even check engine light on...
Old Nov 9, 2007 | 05:02 PM
Chi-Town SRT/6's Avatar
Default Re: Help!!! beeping when i hit 85
where is the beep coming from?
Old Nov 9, 2007 | 05:46 PM
NeverEnough's Avatar
Do these cars have an "Over Speed" alarm? I've had a couple of cars before that had programable alarms that trigger at a certain speed to remind you to slow down. One was a C230 and the other was a Buick Reatta. If they do have this feature, that would explain it...
Any thoughts?
Old Nov 9, 2007 | 06:56 PM
Brent's Avatar
No beeping from my car even in temps lower than 45 degrees. I can't see what difference a lower temp of 45 would make anyway since that's still well above freezing.
Do any of your dash icons light up when the beeping starts? Have you gone through the owner's manual to find all conditions that will trigger an audible alarm? Have you installed any electronics such as a nav unit that may be set to beep at 85 mph? At any rate you have an amusing speeding excuse to provide to the police should you ever get pulled over.
Old Nov 9, 2007 | 07:29 PM
lol the dealer was like why are you going 85 you just left and I know the speed limit on the closest road was 55 lol. Yes i went through everything, Steering wheel, door, seatblet, lights ect. IT is a soon as I hit 85. The only thing they did is adjusted the rear hatch at the dealer and now I come back with this.
Old Nov 9, 2007 | 08:33 PM
RPM's Avatar
RPM
Moderator
I've never heard a beep for speeding in mine. Sounds odd to me.
Old Nov 9, 2007 | 08:43 PM
It is really odd it scares me I want to know what it is..... I am not going to be able to sleep
Old Nov 10, 2007 | 12:03 AM
svo's Avatar
svo
make sure all doors and rear hatch are properly shut
Old Nov 10, 2007 | 02:49 AM
crossfirefun's Avatar
Have them check the computer to see if it is in SRT mode. My convertible would not operate when I got my car and they said it was because the computer was looking for a wing down signal. I have a SRT also.
Not sure if they were telling the truth but my roof works now after 2 days of them screwing around and two interior scratches.
Old Nov 10, 2007 | 08:17 AM
I don't think that would cause a beep. My passenger door was left slightly open last week during a pass at the track and I ran the car up to 120 with no beep. I knew it was open halfway down the track and got a little nervous but kept on pushing.
Old Nov 10, 2007 | 09:50 AM
awsome thats the information I needed I was going to ask someone brave enough to hardly click there rear hatch close and take it up to 85. They ordered a bunch of parts for my car so I need to bring it back I just hope it gets done before it snows...
Old Nov 10, 2007 | 11:43 AM
Brent's Avatar
This actually kind of makes sense. If there are two computer modes, for the standard Crossfire I can see an alarm being sounded at higher speeds to warn if the wing has not deployed. Now if only someone with a standard Crossfire could disable their wing and then drive over 85 to see if they get an alarm.
Old Nov 10, 2007 | 12:19 PM
ShawnQ's Avatar
I re-adjusted my hatch, and it was tough to close...
So, make sure it is closed. Whether or not it caused a chime, I don't know...as I re-closed it and made sure it latched.
SQ
Old Nov 10, 2007 | 01:46 PM
Brent's Avatar
If your hatch is really difficult to close then your bumpers have been moved too much. Try moving the bumpers back a tad then try closing your hatch.
Old Nov 10, 2007 | 02:00 PM
Thats the only thing they messed with so that has to be the problem.... Have you had this problem before?
Old Nov 10, 2007 | 02:33 PM
ShawnQ's Avatar
I over-adjusted mine a hair to where it was tough to close.
Then, close the hatch hard and they move just enough to be just right.
SQ
Old Nov 10, 2007 | 02:48 PM
Brent's Avatar
I don't know if the hatch is causing your beeping issue but you can check if your is closed by using your interior lights. Set your light switch is set so that your interior lights come on when the door is opened, and then fade out after about 10 seconds when the door is closed. If your hatch is not securely closed then the lights will not fade out but stay on.
As for the bumper adjustment I thought I read somewhere in the maintenance manual a complete procedure for adjusting the bumpers and torquing them down 88 in-lbs but can't find that info now, at least in the standard Crossfire manual. Will see if I can get a copy of a manual for an SRT6 and look in that.
Old Nov 10, 2007 | 04:47 PM
anyone willing to not click there hatch down tight and take it over 85
Old Nov 10, 2007 | 05:37 PM
I can try it at the track tommorrow if it does not rain. Hopefully the hatch doesnt fly open causing me to take off into the air like a cessna!
Old Nov 10, 2007 | 06:06 PM
Thanks chi-town ohh by the way make sure to mount a camera on the dash so when you do go airborn you will have proof, and then you can change your description to read "world quickest srt6 and only srt6 to go to take flight"...
