6'2 230 pounds... Will I fit in the Crossfire!!!
Old Feb 4, 2008 | 08:26 AM
redlinedrummer's Avatar
Default 6'2 230 pounds... Will I fit in the Crossfire!!!
I am a huge weightlifting freak and was wondering if I'm just to big for this car!!!! I'm 6'2 230
Old Feb 4, 2008 | 08:29 AM
Default Re: 6'2 230 pounds...Will I fit in the Crossfire!!!
I'm 6'1, 200 and would want to be any bigger in these cars. But, you'll never know for sure until you get into one and drive it.
Old Feb 4, 2008 | 08:30 AM
RPM's Avatar
RPM
Moderator
I'm 6'2" 250 pounds and I fit. Plus I wear a size 14 shoe.
Coupe was a little snug for me, but the Roadster is a nice fit.
See if you can find one near you and try it out.
Old Feb 4, 2008 | 08:33 AM
BuffNSoFly's Avatar
Im also a weightlifter (5'8 235lbs) and I get tons of comments such as:
"Can your arms fit in that car"
"I bet your smushed in there"
Adjust your seat and such im sure you will find something comfortable.
Old Feb 4, 2008 | 08:49 AM
BrianBrave's Avatar
<--- Huge Horsepower
I am a huge weightlifting freak...
Wouldn't a "Muscle" car be a better fit?
Old Feb 4, 2008 | 09:28 AM
Opticon's Avatar
6' and 265 in a coupe.
It's a little tight getting in and out, but if you're flexible you won't have a problem.
Old Feb 4, 2008 | 09:48 AM
cgocifer's Avatar
Dude, just get a Hummer! How about a 300 SRT8?
Old Feb 4, 2008 | 10:24 AM
NeverEnough's Avatar
I'm 6'1" and 260 and fit just fine. Once you get in it, it's very roomy unless you have an extra large head. I don't have bout about 1 inch of head room left, BUT all my height is in my upper body. 6'1" with a 28" inseam. Yeah, I'm freak. Anyway, if you are more evenly proportioned than myself, you should still fit.
Old Feb 4, 2008 | 10:25 AM
itsallu's Avatar
Or a minivan and take out the driver seat to cruise from the 1st bench.
Old Feb 4, 2008 | 12:45 PM
RIOT's Avatar
6'3" AND 224 and I do not fit im my friends coupe but I do fit in my Roadster
Old Feb 4, 2008 | 02:15 PM
Opticon's Avatar
7 way adjustable seats help too. My base seats fix the tilt angle of the seat bottom. That greatly limits the possible body angles that could keep your noggin out of the headliner.
EDIT: Also provides no support for the underside of your legs of you sit like I do. It feels like i'm holding my leg overtop of the accelerator instead of tilting my foot into it. Really annoying.
Old Feb 4, 2008 | 03:17 PM
R.S.'s Avatar
I'm 6ft and 240 and I fit in my roadster with no problem. The seat adjustment is not all the way back so I believe you might fit. It is wide enought,I'm a martial arts instructor and done my share of weight training.
R.S.
2005 srt roadster # 57588
Old Feb 5, 2008 | 01:36 PM
jackei's Avatar
try it yourself personally. I'm 6 ft and I barely fit in comfortablly. It has lots of legrooms, but i hate my hair touching the roof.
Old Feb 5, 2008 | 05:19 PM
MD SRT6's Avatar
I'm 6'3 and 200lbs and it is horrible over 10-20 miles of driving. But not bad for a shorter trip. Head about .5 in from headliner, Legs not so bad. But I use mine for drag racing only. I would not reccomend it for a person your size for daily driving.
Old Feb 6, 2008 | 10:03 AM
LEADFOOT's Avatar
I am 6'2" and 240. Plenty of room for my shoulders,hips and legs. A little tight in the head height dept. It wouldn't stop me from buying it all over again
Leadfoot
Old Feb 6, 2008 | 10:34 AM
+fireamx's Avatar
I'm 6'2", 215lbs. and I didn't think I could find a comfortable position in the Crossfire until a salesman showed me a trick with the power seat. First he lowered it as far as it would go, then he put the seat back in a straight up position. Finally he slid it all the way back until it wouldn't go back any further.
When I got in, I moved the seat forward until my knees were about 1" from the dash board, and then I raised the bottom cushion up in front until it was right where I wanted it to be. Next I tilted the seat back as far as it would go and everything felt great.
There are taller people than me on the forum who have Crossfires, some even with coupes so Redlinedrummer you should be able to find that "sweet spot" if ya play around with the seat adjuster.
For the record, I've spent more than 12 hours straight in my Crossfire and got out feeling like I coud have gone a few more.
Old Feb 6, 2008 | 12:57 PM
Osofast2's Avatar
6 '3 And 215 Works for me !
Old Feb 6, 2008 | 01:15 PM
spensley's Avatar
Go and sit in one!!!
(6'2" 215lbs)
Old Feb 6, 2008 | 01:34 PM
antonio311's Avatar
The roadster will give you 3-4 inches more head room, the coupe may be a bit tight. Rent one for a few days, to see if its a bareable fit. I'm 5'9" and 150 lbs and i fit just right! A larger frame may be too cramped, and that could be a Co$tly mistake. Let us know what u decide.
Old Feb 6, 2008 | 01:44 PM
RPM's Avatar
RPM
Moderator
What?! Try closer to 1/2 inch.
http://autos.msn.com/research/compar...98936&v=t98935
