How its made Issue #11
Old Jun 11, 2008 | 03:32 AM
waldig's Avatar
Talking How its made Issue #11
Circulator Pump Wanna see inside ? Me too.
I had been troubleshooting a bug in the throttle circuit and wanted to be sure that the H/E circulator pump was not an issue.......so I replaced my stock pump with the Johnson.
The stocker has one nice feature, it has no rotation seals, as it is magnetic drive with two magnets coupling the torque to rotate the impeller.
The photos give you a simple view of the two brush motor and the impellers, yadda yadda. Whats interesting is the slime that was on the impeller and NOT ON ANYTHING ELSE. Using stock antifreeze, I would not have expected this as everything has been kept very clean and fluid was strained when reinstalled. It was fairly thick and wiped off like some sort of waxy material, all other passages were clean?
The stocker was well built and I believe that there was no impending problem, so Ill reassemble it and keep it as a good spare as needed. The black is brush carbon and you can zoom in on the various parts to see whaats zuup inside to satisfy your curiosity. Hope yall enjoy the view.
Woody
Old Jun 11, 2008 | 03:44 AM
BrianBrave's Avatar
<--- Huge Horsepower
Default Re: How its made Issue #11
Thanks for the pics - My stocker was still running when I replaced it but with very weak flow. I could pinch off a hose with my fingers and stop the flow with no problem. The way my setup is now - I will probably stick with the CM30 or go with a pump I saw made by Meziere.
Old Jun 11, 2008 | 06:31 AM
ws6vert's Avatar
I've been wondering if I should change mine to the Johnson even tho I've had no problems.
Old Jun 11, 2008 | 09:47 AM
crossfirefun's Avatar
Same here. I dont want it to go when I least expect it.
Old Jun 11, 2008 | 10:47 AM
Voyager's Avatar
i got mine replaced with by the dealership and then replaced it with the johnson pump so i always have a good stocker to go back to if i ever need one
Old Jun 11, 2008 | 02:37 PM
nubie2xfire's Avatar
I am sure that all the other nubies on this forum wants to thank you Woody for all the great info aand pics you provide,
Thank you so much!!
Old Jun 11, 2008 | 05:39 PM
Kurts's Avatar
That's actually a darn good idea!!
PNA
Nov 12, 2020 04:44 PM
maxcichon
May 14, 2019 07:30 PM
Adrian_X
Nov 9, 2017 08:49 AM
dbooso
Aug 27, 2015 11:03 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
