lowering my Srt?
Old Jul 2, 2008 | 11:57 AM
pushingthroughthis@yahoo's Avatar
Default lowering my Srt?
Anyone have any advise on what springs are the best for lowering my car? i've seen eibach has some springs and a few others. looking for suggestions.
Brad
Old Jul 2, 2008 | 12:04 PM
crossfirefun's Avatar
Default Re: lowering my Srt?
Welcome to the forum. Check around in this section: I haven't lowered mine so I can't help.
https://www.crossfireforum.org/forum...splay.php?f=89
Old Jul 2, 2008 | 01:48 PM
waldig's Avatar
Talking Re: lowering my Srt?
I used the Eibach springs on my SRT but finally pulled the fronts off and went back to stock because Autocrossing made the tires rub in hard corners.
The lowering also adds angle to the camber, so you have to consider that also. It handles ok now so lowering is a looks thing mostly, Woody, Enjoy.
Old Jul 2, 2008 | 02:03 PM
RPM's Avatar
RPM
Moderator
If you have a SRT6 Roadster, don't go with the Eibachs. They will work on the SRT6 Coupes though.
Old Jul 2, 2008 | 03:23 PM
240M3SRT's Avatar
I agree completely. BDJ's lowered his car with Eibachs and it rubs on the higway at 80mph when theres a big dip or bump. It rides a bit smoother but sways way more in the turns. Also consider the decreased clearance under the car.
Lowered srt6's look absolutely sick. But im keeping the stock springs on my car due to great handling and good ground clearance. The way AMG designed it.
Old Jul 2, 2008 | 03:30 PM
I'm experimenting w/ SLK side skirts to give the appearance of being lowered, will go with 19's front, 20's rear when I finally decide on a wheel and tire package....this should give a lower appearance...
Old Jul 2, 2008 | 03:45 PM
coony3737's Avatar
I have the eichbach pro series on my srt roadster and would do it again in a second. The only time I rub is when reversing while turning hard, other than that my tires don't rub at all. When installing the springs I shaved the rubber isolators(3/4") instead of buying the shorter ones from mercedes, this may be the reason I don't get any rubbing. I autcross my car and also generally run the **** out of it and with the eichbachs it handles considerably better. In stock form my car would push in the corners fairly bad but now with these springs it's a whole new beast. Understeer is all but solved and everyone who rides in my car says it handles like a go kart.
-Josh
Old Jul 2, 2008 | 06:51 PM
Thanks a bunch for the input i think i'll order the pro kit. i'll be asking for more help along the way.
Bradley
Old Jul 5, 2008 | 06:11 PM
SRT6nTulsa's Avatar
Question Re: lowering my Srt?
-Josh
Shaved the isolators? You didn't happen to take pictures, did you?
Old Jul 7, 2008 | 06:33 AM
coony3737's Avatar
Nope I sure didn't. Sorry.
Old Jul 7, 2008 | 09:03 AM
apkano's Avatar
Life is random...so am I.
Being as you live in Wisconsin, I have to ask. Do you plan on driving the car all year?
I considered lowering mine as well, but I think it would do bad things in the winter months. 4 inches of snow is no problem now, but after lowering I think it would not make it.
Just something to think about!
Old Jul 7, 2008 | 04:29 PM
i keep mine in storage all winter and don't really drive it to often, so that's a non issue for me.
Roty135
17
Oct 11, 2018 10:11 AM
maxcichon
Sep 4, 2015 08:43 AM
waldig
Jul 20, 2015 08:10 AM
2004_
Jul 13, 2015 02:04 PM
turboomni08
Jul 7, 2015 11:48 AM
