Where to put O2 Sensor for Wideband AFR Gauge
Old Dec 22, 2008 | 06:40 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Default Where to put O2 Sensor for Wideband AFR Gauge
After using my ole search button I am finding some differences on where people placed their O2 sensors for their Wideband kits. I know that 240M3SRT6 put his on the header before the first set of cats but I also see Waldig put his on the exhaust downpipe after the cat. The wideband kit says to put it before the cats, but of course it also says at least 18” downstream from the header and that is impossible on our cars! Also, we have two sets of cats so that makes me have even more???? Any input would be most appreciated!!! I am using the brand new Prosport AFR gauges with the heated Bosch O2 sensor. Where should I weld this "bung"???
Old Dec 22, 2008 | 07:07 AM
distantpulse's Avatar
Default Re: Where to put O2 Sensor for Wideband AFR Gauge
I put mine on the passenger side exhaust right after the first cat. I believe this is ok for general readings, but the way 240 did his is probably more accurate.....
Old Dec 22, 2008 | 07:28 AM
I put mine on the drivers side between the two cats,, then checked it with the dyno reading,, both read the same so i guess it is ok where i put it, also amjerry did my tune and set the af at 11.7 to 12.1 and my readingin the car is 11.7 at wot. with SC pully, 16lbs of boost so i could run a few more lbs of boost without adding fuel. jim
Old Dec 22, 2008 | 07:42 AM
NeedsWings's Avatar
pass side (as its last to get fuel) just after the primary cat
Old Dec 22, 2008 | 07:43 AM
BLKFIN's Avatar
ADDICTED TO BOOST
Thanks for the input guys! Most helpful!!!
Old Dec 22, 2008 | 11:27 AM
waldig's Avatar
Talking Re: Where to put O2 Sensor for Wideband AFR Gauge
Here is the photo,FYI, Wideband readings matches the factory sensor reading from the cars O2 sensor.
ENJOY< WOODY< Happy holidays and merry christmas...
Old Mar 28, 2010 | 01:22 AM
billvp's Avatar
Sorry to bring this thread back from the grave, but may as well put it here for future searches.
Where is the best place to have install a wideband o2 sensor? Do you pretty much need to go to a speed shop, or will a muffler shop work alright (or would they even try)?
Old Mar 28, 2010 | 01:35 AM
I would think any muffler shop would do just fine
KDW4Him
18
Sep 1, 2021 05:47 PM
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
RacerXofFL
Sep 15, 2015 05:00 PM
axnguyen
Jul 21, 2015 11:41 AM
