Boost for Dummies Question
Old Apr 24, 2009 | 01:25 PM
tom2112's Avatar
She can ride with me ;)
Default Boost for Dummies Question
OK, I'll freely admit to knowing a lot more about physics than I do about engines, and I'm no physics expert, so bear with me.
I recently got a dashdaq, and one of the readouts it has shows the MAP or intake Manifold Absolute Pressure, and that this pressure readout includes atmospheric pressure. Also, I understand that atmospheric pressure at sea level is typically 14.7 psi.
So, to make a poor man's boost gauge, you can simply subtract 14.7 from the MAP readout and that's your boost. Well, I tried this, and I must have goofed something up. So I switched back to just logging/viewing the MAP readout.
The MAP readout confuses me. It ranges from 2.9 all the way up to 27.0.
There's two big issues I don't understand:
1) At full throttle and max RPM what should my MAP be reading? Shouldn't it be higher than 27 psi? At 24 psi that would indicate I was only boosting about 12.3 psi. Isn't that low, especially considering my mods? Doesn't the stock supercharger boost around 14 or 15?
2) How can there be a negative boost? I understand that represents vacuum (or sucking on the part of the engine). But that seems impossible to me. How can the supercharger be spinning and not compressing the air?
Old Apr 24, 2009 | 02:45 PM
SRT6-Man's Avatar
Default Re: Boost for Dummies Question
I just got my boost gauge hooked up today, I'm hitting between 12 to 14 psi.... The car runs like a bat outta hell...... Maybe we got the weaker SuperChargers put in our cars at the Factory .......LOL.
Old Apr 24, 2009 | 04:15 PM
Montana Crossfire's Avatar
Yes the standard stock S/C is running 14 lbs+. But I have heard that the Cade3 typically only runs like 17. I could be misinformed but I think thats about all you might expect.
But in all reallity 17Lbs of boost is quite a bit. I get 24 on mine with a 185mm.
Plus it is far better to have a good knowledge of physics than cars. You will discover if more of these guys had a good understanding of physics there would be a lot less rediculous arguments.
Old Apr 24, 2009 | 04:28 PM
LantanaTX's Avatar
Even a supercharged car will show vacum during deceleration or when reving the engine when not under a load.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
Sep 28, 2015 07:40 PM
