limited springs on srt-6
Old Jul 11, 2009 | 11:30 AM
Default limited springs on srt-6
well I had the dealer install my limited springs on my srt,, the front droped about 1" the rear something was wrong as it went higher so i had them put the stock ones back on the rear,,, , i am not sure what happened did they put the front srt springs on the rear ,,that raised it up the reading from the ground to the lip of the finder before was front 26 1/8" ,,rear was 27 7/8",, now it is front 25 3/16",, rear 27 7/8,, when it was high it was 29.5" that is why i had them put the stock ones back,, does any one have a way to identify the springs on the limited and the srt. and does any one know the spring rate of each,,
as for ride, it is softer with just the front limited springs installed, does any one have a set of springs out of the car so we can post the hight and the diameter of the springs and what car, srt, limited, or base they are from. the ones i have are, 14" long / 610= .5 3/32 diameter,, the 15" long ones are .550 = .5 1/32diameter here are the pic of the car lowered in the front with limited springs. jim
Old Jul 11, 2009 | 11:33 AM
Default Re: limited springs on srt-6
pic. of the front the back is still the same, will take a pic and post it
Old Jul 11, 2009 | 11:41 AM
pic of the springs and diameter, jim
Old Jul 11, 2009 | 11:43 AM
Montana Crossfire's Avatar
You need to get the spring rates in the same ball park or your handling is going to really suffer!
Old Jul 11, 2009 | 11:45 AM
it handles great with this set up and at the drags the front lifts enough to improve my 60"
Old Jul 11, 2009 | 11:46 AM
There is no way they could put rears in the front and vice versa. Totally different diameters.It sounds as though they didn't have the springs seated all the way in the rubber pads. I have a set of stock SRT springs at home if you want me to measure them to check yours out to see if you have the right ones....
Mike
Old Jul 11, 2009 | 11:48 AM
I forgot your a "LIne Jocky" for a minute I thought I was talking to a "Driver" Just kidding so don't get in an up roar.
Mike
Old Jul 11, 2009 | 12:00 PM
Mike
sorry my wife drives the car in the road course, it's called I-95 LOL yes drag racing, just put your foot into it and hang on i don't have to move the steering wheel , where at the road course you have to turn ,,brake and watch out for the one that can't drive. \\\ oh just test tune road course is 300.00 for 5 to 10 pm.. the drag race test tune is 25.00 jim
Old Jul 11, 2009 | 12:04 PM
Mike
yes measure them,,I have in a box 4 springs two are srt rear and 2 are limited rear which is which i don't know thanks jim
Old Jul 11, 2009 | 12:15 PM
will do I will send you measurements this afternoon...
Old Jul 11, 2009 | 09:46 PM
Letxen3's Avatar
Old Jul 11, 2009 | 09:58 PM
this mustang had a corba motor in it, he said it had about 500 hp , i ask why on street tires, it was the first time he ran it a a drag strip we ran 3 times then he gave up ,, I was running 12.7 on all my runs and my 60" was 1.81 mph was 108 to 111. seems like every time i go to the strip, mustangs want to run me and then they loose..
Old Jul 12, 2009 | 10:16 AM
I will try to do with the rear springs soon, jim
Old Jul 13, 2009 | 03:02 PM
thanks to Andrew for this info. on the base to the srt-6
"They began by significantly increasing the spring rates, and SRT-6 Coupe and Roadster models are tuned differently, to their own unique
characteristics. The Coupe's spring rates are 451 lb./in. in the front and
480 lb./in. in the rear, while the Roadster's are 434 lb./in. in the front and
451 lb./in. in the rear, compared to 303 lb./in. front and 337 lb./in. rear on
the base Crossfire Coupe and Roadster models."
I need a complete set of base springs. jim
Old Jul 17, 2009 | 01:16 PM
240M3SRT's Avatar
So limited springs are different from base? I thought the only difference was srt6 vs na.
How much better is the ride do the na springs make it much softer even with the srt6 shocks? I have a set of na springs in my garage i have been waiting to put on.
Old Jul 18, 2009 | 08:55 AM
I don't know if base and limited are different but , i need a complete set,, as you know i installed the front only droped the srt 7/8" ans the ride is much softer aith the rear installed if i ever get there it should be great. jim
xfireohio
Jul 20, 2020 12:03 AM
wannaGOFAST
South Forum
Aug 14, 2015 01:20 AM
velociabstract
Aug 7, 2015 01:30 PM
Mikerdougie
Aug 2, 2015 02:04 PM
UNDER PSI
Jul 18, 2015 02:12 PM
