Help!!!
Old Nov 9, 2009 | 10:57 AM
miltolam's Avatar
Default Help!!!
Good morning XF enthusiast...for quite some time my trunk light wasn't working. I just never cared to replace it until last week. The auto store gave me the wrong size bulb. It was a centimeter or two short and caused a few sparks while I was trying to install it. A few days later I noticed that the interior lights were not coming on also. I took out the plastic housing to look at both bulbs and they looked fine. When I finally purchased the correct bulb size for my trunk, it did not come on as well so I figured that it was relative to the interior light. Apparently a fuse or something blew however, I cannot find out where it is at. I looked at the fuse box near the driver side door and the chart does not indicate that any of the fuse outlet is for the interior lights. Someone told me that it could be under the hood but before I go messing around, I thought that it would be wise to query this on here. Can somebody give me any insight on this matter, thanks.
Old Nov 9, 2009 | 11:11 AM
hcarter's Avatar
Default Re: Help!!!
Under hood on driverside big black box open you will see the fuses
they should be marked Good luck
Old Nov 9, 2009 | 11:38 AM
miltolam's Avatar
Default Re: Help!!!
@Carter...
Are you talking about the big black box to the right of the battery? If so, it's on the passenger side. I'm at work right now but I think that's what you're probably talking about.
Old Nov 9, 2009 | 11:40 AM
hcarter's Avatar
Default Re: Help!!!
No thats the cpu box it also has fuses but the one you want is on the driver's side ,,
Old Nov 9, 2009 | 11:41 AM
miltolam's Avatar
Default Re: Help!!!
Thanks man, I bet my whole paycheck that the cuse blew...I'll check it out when I get home.
Old Nov 10, 2009 | 08:31 PM
Marine05's Avatar
Default Re: Help!!!
So do you still have your paycheck?
Old Nov 10, 2009 | 09:10 PM
Default Re: Help!!!
too funny....my car gets my paycheck everytime I find another mod I need....ya blew da fuse there...
