does anyone know where i can get a IC pump from?
Old Apr 2, 2011 | 04:13 PM
prandle1990's Avatar
Default does anyone know where i can get a IC pump from?
i have tried autozone, advance, napa and they have no clue what i am talking about....please help
Old Apr 2, 2011 | 04:20 PM
Default Re: does anyone know where i can get a IC pump from?
www.needswings.com Rob has them.
Old Apr 2, 2011 | 04:22 PM
32krazy!'s Avatar
rob has the bosch , parts.com or rockauto.com or apeusa.com for the cm30 . honestly you wont find much for these cars at your local parts house
Old Apr 2, 2011 | 04:23 PM
cool now what is it under? and is it called a IC pupm?
Old Apr 2, 2011 | 04:25 PM
32krazy!'s Avatar
look under the cooling subsection of the srt-6 section
Old Apr 2, 2011 | 04:27 PM
whats a cm30?
Old Apr 2, 2011 | 04:36 PM
32krazy!'s Avatar
whats a cm30?
the cm30 is a different pump that can be used in place of the bosch pump. a little smaller than the oem and flows a tad more
Old Apr 2, 2011 | 04:40 PM
does it cost a lot more?
Old Apr 2, 2011 | 06:29 PM
no, about the same...
Old Apr 2, 2011 | 06:42 PM
ok cool and where do i find those at?
Old Apr 2, 2011 | 06:44 PM
32krazy!'s Avatar
apeusa.com for the cm30. you will need to remove the plug from the old pump and solder it onto the new pump to make it plug and play. also wrap the cm30 in a bicycle inner tube to have a snug fit in the oem mount
Old Apr 2, 2011 | 06:50 PM
which flow and fitting should i get?
Old Apr 2, 2011 | 07:00 PM
32krazy!'s Avatar
the 12volt 3/4 " openings are what you will want. others have also chosen the cm90 for even greater flow but it hasn't proven to be a better unit unless your running a remote tank unit
Old Apr 4, 2011 | 09:17 AM
taz2005's Avatar
Eurocharge carries the Johnson CM30 Intercooler Pump for $175.00. I got one from them, fast delivery.
Old Apr 13, 2011 | 12:19 AM
X-Fire_srt6's Avatar
I just got my Bosch int. cool pump from needswings.com installed today.
Also, you could try the Johnson pump from eurocharged.com
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
