Need SRT6 ABS wiring harness
Old Jul 1, 2011 | 12:59 PM
rmaier's Avatar
Default Need SRT6 ABS wiring harness
I need to know where I can get the ABS wiring harness for an SRT6 '05 to complete my build. Everything is done except for that.
Old Jul 1, 2011 | 03:35 PM
Ottawa John's Avatar
Default Re: Need SRT6 ABS wiring harness
I would think that an SRT ABS system is the same as all Crossfires - or older SLK's for that matter. You can check this out if there are part numbers for them. Then try auto wreckers that are advertising Crossfire parts on ebay or on the used car web sites. You shoiuld be able to find something fairly easy.
Old Jul 1, 2011 | 05:18 PM
rmaier's Avatar
Unfortunately I was told by the dealership that the abs system used a diff communications from '04 to the SRT6 '05.
The N/A system has yaw and some other module subsystems that the SRT6 does not.
I have the '04 N/A that I installed the SRT engine, Trans, Rear end and TCU,BCU and PCU.
The DCU and related modules do not like the N/A ABS and will not read the speed sensor to correctly interface with it. I have the SRT brake ABS system but not the wiring harness and sensor.
The mechanic told me the only way to get this to work is to get the harness and sensor installed into the N/A so the computers play nice together. The original donor car had the wires missing from the cabin to the rear of the vehicle so I do not have those pieces.
m3pig
Sep 15, 2015 05:20 PM
81's
Sep 13, 2015 04:34 PM
RiderJC
Sep 7, 2015 11:19 PM
jaesa
Sep 7, 2015 01:50 PM
crmnal
Sep 6, 2015 08:07 AM
