CHEAP Intercooler Pump & Better then the CM30
Old Aug 28, 2011 | 08:12 PM
kolevski's Avatar
Default CHEAP Intercooler Pump & Better then the CM30
Hi fellas,
I've fallen victim to a failed intercooler pump and in my search for either an OEM replacement or the Johnson CM30 I came across this.
Intercooler water Coolant Pump SVT Mustang SuperCharger | eBay
It's from the Mustang SVT, it's a bargain price and flows MORE than the CM-30.
I believe the CM30 is around 6.9 gallons per minute this flows 8 gallons per a minute.
And plus it looks like a nice small compact unit.
I just ordered a unit I'll let you know how it goes but I'm hoping all will be fine.
John.
Old Aug 28, 2011 | 09:49 PM
cjw's Avatar
cjw
Default Re: CHEAP Intercooler Pump & Better then the CM30
does anyone think its possible that the upgraded ic pumps are whats causing the intercoolers to fail on some srt's
Old Aug 28, 2011 | 10:50 PM
kolevski's Avatar
I think it may be the opposite that failing pumps not delivering enough fluid is not doing the intercooler any help.
Old Aug 29, 2011 | 02:46 AM
Mimi05SRT6's Avatar
Curious to see how it all turns out. Sounds like it might be the same as the Ford Lightning unit that's been mentioned on here. Can't wait to see how the install goes and what parts needed to be upgraded to fit.
Old Aug 29, 2011 | 05:19 AM
Buggin's Avatar
I can't see how an OEM (lower flowing) pump would cause a fluid leak in the intercooler. I am one of the skeptics that thinks there might be problems when going to a significantly higher flow rate. If a pump flows faster then the intercooler can flow, a pressure increase 'could' possibly be an issue at the intercooler. Note, I have NO info to back this, it is purely my thought process...
Old Aug 29, 2011 | 05:24 AM
kolevski's Avatar
You could be right Buggin. What gives me abit of comfort is companies like Eurocharged selling CM30 Johnson pumps I'm sure they'd know the logistics of how they operate and any potential problems.
Basically as we all mod our cars with pulleys and tunes etc, the engine works harder which means it produces extra heat so an upgraded pump that can flow slightly more should be essential in my eyes.
However much like you I also have no theory or evidence to back this up so it's just words at this point.
I'll note I did have a spare intercooler that I sold to a member on here I'm starting to wish I kept it after what you guys are saying lol.
John.
Old Aug 29, 2011 | 05:33 AM
kolevski's Avatar
I'm hoping it will be straight forward without any customisation but I'll soon find out
Old Aug 29, 2011 | 06:13 AM
32krazy!'s Avatar
john right away you will need to solder a resistor and aplug on the end of the wires. as the pump looks from the pics to be much shorter and fatter you may need to fab a bracket to fit the pump in the oem holder
Old Aug 29, 2011 | 06:32 AM
kolevski's Avatar
Hey Steve why do you think I'll need a resistor? I was just planning on soldiering the wires from the pump to the original harness. Didn't think I'd need a resistor but I may be wrong. Lucky I have you guys
John.
Old Aug 29, 2011 | 07:17 AM
tunaglove's Avatar
Give it a try, honestly it looks cheesy. Might be a good bargain but ebay stuff.......
Old Aug 29, 2011 | 07:24 AM
what is the psi of the stock? ,, the Johnson pump, and the mustang pump.. if that makes a difference...
jim.
Old Aug 29, 2011 | 08:01 AM
32krazy!'s Avatar
John.
if you take the oem plug apart to reuse you will find a small resistor in place. i was told by the electronics shop that its used to absorb any voltage spike from the pump kicking on. mine was maybe 1$? i wanted to make the cm30 i was using to be close to stock as possible so i replaced it . you could prolly get away by not using a resistor
Old Aug 29, 2011 | 10:11 AM
waldig's Avatar
Talking Re: CHEAP Intercooler Pump & Better then the CM30
I believe that the resistor in question is in fact a DIODE with the band - striped end on the + lead. That would make electrical sense.
The fluid circuit determines the flow as much as the pump. If there is a lot of restriction, the flow will be limited. Flow is a combination of the pumps psi at a given flow and the restriction of the circuit, ie the resistance in the piping.
Iam here to tell you that intercooler leaks are not caused by the pump, its the static pressure when hot. People that have done the Brian Black separation of the IC cooling circuit from the engine have almost no pressure on the IC while the motor and main radiator have like 15-20+ psi EVERY time the motor heats up, and like an accordian, the metal flexes and stresses the IC welds and parent materials.
Enjoy Woody BTW I drilled my cap so I can run the engine at ZERO psi when hot if the cap is loose. I run with the cap loose.....................
Old Aug 29, 2011 | 10:42 AM
tunaglove's Avatar
Doing this will ensure you never have a pressure build up in your separated IC circuit. This is a BMW steering fluid reservoir and it has a vented cap.
Old Aug 29, 2011 | 11:32 AM
Buggin's Avatar
And THAT is why we love you Woody! You bring rational thought to us idiots. lol
That make 100% sense. Thanks!
Old Aug 29, 2011 | 10:01 PM
kolevski's Avatar
I had a set up like this before I got the Needswings coolant separation kit.
I'm still thinking of adding the reservoir I had and connecting it to the overflow like yours, but leaving the original hose from the Needswings kit that connects from the OEM coolant reservoir closed off from circulating to the inter cooler.
Does your reservoir have any hoses on the bottom of it going anywhere? I hope what I've written so far makes sense lol.
John.
Old Aug 30, 2011 | 08:53 AM
tunaglove's Avatar
This is seperated just like when you use the kit. There are two ports on the bottom of the reservoir. One is capped off and the other plumbs in to the return line for the I.C. using that plastic factory tee. Only a small bit of coolant bleeds constantly and the reservoir is the fill point. So this is a seperated I.C. circuit.
Old Aug 30, 2011 | 12:06 PM
latemodel21's Avatar
tunaglove,
do you have a part number or bmw application for this reservoir.
It looks like a really nice fit. I'm gonna want one of those!
Chris
Old Aug 30, 2011 | 12:18 PM
tunaglove's Avatar
Bmw E46 E39 325i 525i X5 Power Steering Reservoir Tank | eBay
there's a ton on ebay.
Old Aug 30, 2011 | 12:23 PM
thanks for the link tunaglove!
would I be correct in assuming that the nipple in your pick was added by you (and does not come on the reservoir)?
