Needswings mani gaskets
Old Nov 14, 2011 | 04:44 PM
svtcobra's Avatar
Banned
Default Needswings mani gaskets
for those of you who are running needswings mani gaskets are yall using sto oem gaskets or the cork gaskets. I tried to install nw cork gaskets when i turned car on it was ideling like at 3k rpm. maybe i installed them wrong
Old Nov 14, 2011 | 04:59 PM
pjpsrt's Avatar
Default Re: Needswings mani gaskets
did u two step torque to 120 in/lbs per website?
we just last week put some on
they'll freak u out at first
Old Nov 14, 2011 | 05:09 PM
velociabstract's Avatar
Did you miss the cork O's that go under the outside bolts?
Les
Old Nov 14, 2011 | 05:28 PM
pjpsrt's Avatar
hoses? sc to y, y-mani
Old Nov 14, 2011 | 05:36 PM
32krazy!'s Avatar
one gasket needs to be flipped to properly line up the mount holes. recheck the gaskets
Old Nov 14, 2011 | 06:00 PM
Squirrel Crusher's Avatar
I spray contact cement over the side of gasket that will mount towards the removed intake manifold. After a couple of minutes of tack drying time,I elign the gasket to the intake manifold,then firmly press down the gasket. After several hours of final drying time or next day,I bolt them to the block. Only after smearing anti-seize onto the manifolds bolt's threads. For the next 5 days of driving the car,I recheck the torque after the engine has had all night to cool down. I'm running a 185 pulley and haven't had a gasket failure yet. Works for me anyway. Squirrel Crusher
Old Nov 14, 2011 | 08:55 PM
NeedsWings's Avatar
something is wrong, call me tomorrow and ill walk you thru it
Old Nov 14, 2011 | 09:08 PM
32krazy!'s Avatar
bet you a club sandwhich rob he has the drivers side gasket upside down
Old Nov 14, 2011 | 09:09 PM
NeedsWings's Avatar
i prefer corned beef or roast beef, better make it a french dip
Old Nov 14, 2011 | 09:23 PM
MikeR's Avatar
mmmmmmm.... corned beef....
Old Nov 14, 2011 | 10:54 PM
svtcobra's Avatar
Banned
O woww actually i didnt even realized the gaskets came with O gaskets also i didnt even put those on also instead of using the 3m i got sm gasket sealer stuff it kinda like a thick paste. i guess thats why its good to follow directions huh
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Sep 26, 2015 10:21 PM
josh armstrong
Sep 22, 2015 01:19 PM
waldig
Sep 17, 2015 10:35 AM
RacerXofFL
Sep 15, 2015 05:00 PM
