Electric Motor switches on???
Old May 13, 2012 | 10:12 AM
Adam Downunder's Avatar
Default Electric Motor switches on???
Hi All,
Does anyone know what is happening??
Whenever the temperature reaches about half (normal operating temp) and I pull up to a stop, I hear a noise coming from the engine bay that resembles a small motor turning on (sounds like windscreen washer motor) then switches off again. When this happens the engine revs about 1000rpms higher then drops back off?
I don't think it is anything that effects the performance, but is it something could lead to nastier things, something that isn't working properly?
Is it a sensor turning something on or off?
Guys, I would appreciate any advice you could share..
I should probably add that my car has done 27,000 miles, has anyone else had the same issue?
Cheers
Old May 13, 2012 | 11:13 AM
tunaglove's Avatar
Default Re: Electric Motor switches on???
It's testing the SAI system. Normal, if the pump fails you will get a P0410 CEL.
Old May 14, 2012 | 06:55 AM
Cheers and thanks Mate!
You have put my mind at ease..
Osusannah
Feb 12, 2024 01:49 PM
franklindm
Mar 14, 2020 12:23 PM
o55ie18
Oct 5, 2015 05:50 PM
Oct 1, 2015 01:42 AM
Charlesl
Sep 30, 2015 10:46 PM
