Car pulls to the right.
Old Aug 22, 2012 | 08:43 PM
The Beep's Avatar
Default Car pulls to the right.
Brought it to a Firestone a few months back because it's pulling slightly to the right.
I picked up the car and they said they did the front only and cannot do the back. I did a search and found out this was true however the car was still pulling slightly to the right.
I thought it was because if the 7yo tiires.
I just replaced 4 tires and the car is still pulling slightly to the right.
Should I bring it back to Firestone and say in a nice way, say "WTH ?
Old Aug 22, 2012 | 09:22 PM
Default Re: Car pulls to the right.
Steer to the left..........lol OK....you really need to have the rear end aligned as well... So, if your Firestone store can't, move on to someone who can...
Old Aug 22, 2012 | 09:36 PM
The Beep's Avatar
There was a thread on here that quoted the service manual that the cambre cant be adjusted on the rear. I don't know about any other adjustments to the rear or if it all requires specialized equipment that Firestone doesn't have.
If that's the case, they should have said up fromt that they can't do it. I paid them about $70.
Old Aug 22, 2012 | 09:38 PM
Infinity's Avatar
They did not do your fronts at 70.00. To properly adjust front alignment you need a set of repair bolts form the dealer which are about 35.00 each and you need 4 of them to do the front. Camber is fixed in the rear so there is no adjustment
Old Aug 22, 2012 | 09:47 PM
the rear still has to be checked... we did after wavetrac install to make sure we were still in alignment.... each to their own...but mine doesn't pull right...
Old Aug 23, 2012 | 03:39 PM
cudaman's Avatar
Camber arms in the rear will help get you to where you might want to be. This holds true especially if you are lowered. And, front camber kit I believe you only need just 2 bolts, but they only give about +-0.5 in camber adjustment. See the link below for more.
https://www.crossfireforum.org/forum...your-ride.html
mhajek18
Dec 30, 2015 03:40 PM
syfi
Jun 22, 2015 07:23 AM
carmax
Jun 18, 2015 01:30 PM
kusheen
Sep 18, 2003 09:29 PM
texex91
Jul 14, 2003 09:04 PM
