crankshaft woodruff key
Old Oct 23, 2012 | 04:05 AM
bundy_bowler's Avatar
Default crankshaft woodruff key
I finally got around to installing my 181mm ec pulley kit only to find that when I took the stock pulley off that to my shock and horror the woodruff key was missing???!!!! I've found the part number from searching these forums but can't locate one to purchase. Does anyone know the measurements of the key so i can source one or have my machine shop at work fab one? Thanx.
Old Oct 23, 2012 | 07:46 AM
xman03's Avatar
Banned
Default Re: crankshaft woodruff key
What's the woodruff key?
Old Oct 23, 2012 | 08:27 AM
Abaton6's Avatar
Woodruff Key - Key Stock - Fasteners - Grainger Industrial Supply
This may help, but I don't know the size.
Old Oct 23, 2012 | 09:58 AM
DTMenace's Avatar
The "Woodruff Key" is not reuseable, any time a crankshaft pully is removed, a new key must be used. Do you have a Mercedes Benz dealer in your area, if you do, contact their parts department and they will supply you with the new key or advise you of the size. Good luck!
Dennis
DTMenace
Old Oct 23, 2012 | 10:13 AM
magredvet's Avatar
As far as i am aware, the crankshaft BOLT is not to be re-used, but I've never heard of anybody having to buy a new woodruff key, of course I have been wrong before............
Old Oct 23, 2012 | 02:05 PM
x2,,, i have used old , and new only if the old one was screwed up or lost for the last 55 years working on different cars,, i just looked I have a offset woofruff key, but for a different car jim
Old Oct 23, 2012 | 02:45 PM
Default
I haven't reused the crankshaft bolt, I've got a new bolt to go in with my new pulley just not a key. If we were meant to change the key every time we changed a pulley wouldn't we be supplied one with our pulley kits from eurocharged? I've kept searching for the part to no avail. Would really appreciate if someone knows where I can get one from
Old Oct 23, 2012 | 05:19 PM
^^^+1^^^^^
Then Repair Manual does not mention replacing the key either.
The key will be to the DIN standard (metric) and not the SAE standard (inch).
Old Oct 23, 2012 | 07:09 PM
magredvet's Avatar
Did you have the keyway pointing up when removing the pulley ? I find it strange that it's missing, unless someone has been there before. I would pull the seal and check it hasn't been pushed out of the keyway, back towards the timing gear. as far as getting a new one, I would think a Benz dealer would be your best bet, unless you can find someone splitting a motor. Have you e-mailed Rob at needswings , or Mr Mopar to see if they can help ? Sorry I can't be of any more help........
Old Oct 23, 2012 | 10:45 PM
rmaier's Avatar
I have replaced the key for the crank and you can purchase them at the Chrysler dealership. I paid $6.34 for mine and it took 3 days to get in. But it had to have a key to begin with or the pulley would not keep the position on the crank with just the bolt.
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
fastfred
Sep 24, 2015 03:05 PM
