Just changes IC Pump
Old Mar 11, 2013 | 02:08 PM
roncosrt6's Avatar
Default Just changes IC Pump
I just replaced the bosch IC pump this weekend. Have approx 36K miles. I'm surprised lasted that long. I wanted to keep bosch, didn't want to have to modify. Process went smooth, thanks to DIY on site. The 5th screw/bolt stumped me for a while. I didn't see this on search, I just dropped the under engine panel and could get to that screw/bolt really easy. Thats, for DIY..
Old Mar 15, 2013 | 12:55 PM
zombiehunter's Avatar
Default Re: Just changes IC Pump
Fifth screw? Was that the one that you needed to use an extension to go to from the front?
Old Mar 21, 2013 | 01:34 PM
roncosrt6's Avatar
I couldn't get at from front. Like I said, removed cover under motor and it was a straight shot.
Old Mar 30, 2013 | 09:35 AM
tbudlee's Avatar
where is the DIY for this change?
Old Mar 30, 2013 | 10:29 AM
velociabstract's Avatar
I dropped the belly pan too. It's a little awkward and in my case messy but easy enough. The new pump keeps the water cooler longer but it ends up at the same temperatures as before.
Les
Old Mar 30, 2013 | 09:32 PM
Billy22Bob's Avatar
in the dead ones...is it purely - "electrical death"?
has anyone observed impeller wear on the "old v new"?
Old Mar 30, 2013 | 09:54 PM
Mine's staying unopened for now. The pictures of bad pumps I've seen (on this forum BTW) had broken impellers. I've never heard of one failing electrically. But I've only been here since ... 2008.
LES
Old Mar 30, 2013 | 10:20 PM
This is for a Johnson install but it is similar and easier to do the Bosch.(click)
Old Mar 31, 2013 | 05:22 PM
tbudlee's Avatar
Thank you, this will be very helpful.....now got to get one and hope it fixes the problem....it is occasional and only when I have been driving for sometime.
Old Apr 1, 2013 | 12:03 PM
roncosrt6's Avatar
If you stay with standard pump, and know where that 5th screw is, it is no longer than 2hrs.
I clamped both hoses and lost minimal amount of fluid.
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
tritongreen
Sep 18, 2015 07:32 AM
81's
Sep 13, 2015 04:34 PM
