Propshaft Couplings
Old Apr 16, 2013 | 06:02 AM
Steve - UK's Avatar
Default Propshaft Couplings
Ive just done some research having noticed some slight cracking in the rubber Flexible Coupling (or donut) at the rear end of the propshaft. The front coupling is fine probably because it runs in - line where as the rear one takes some more flexing as the rear supension moves. Having checked out the MB info on this it seems that some SLK's have had failures of the part with catastrophic results so worth checking and changing if any signs of cracking. This can be due to age/mileage or lots of hard acceleration. It seems that while the standard SLK can have this issue, the AMG versions eat these couplings for breakfast. I would recomend inspection and replacement if any signs, especially if the miles are creeping up, and even more so on SRT models as mine has done 33K and last only owner was a lady! The MB part numbers are different for standard SLK and AMG as the more powerfull car version is much more beefed up. AMG version is part number 203 410 0215 £79.00+Vat from your local MB dealer.
Old Apr 16, 2013 | 06:33 AM
S. Artee's Avatar
Default Re: Propshaft Couplings
In the interest of saving time, do you know offhand what the torque specifications of the fasteners should be for reassembly?
Old Apr 16, 2013 | 09:06 AM
Steve - UK's Avatar
Tighten the bolts to 60 N·m (44 ft. lbs.).
Valk
Jul 12, 2021 09:49 PM
Bloo Ize
Crossfire Events and Meets
88
Sep 10, 2016 08:14 PM
Speedy4x4
Sep 22, 2015 09:50 AM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
