Unhappy roadster...
Old Dec 19, 2013 | 03:04 AM
Tp'sfury's Avatar
Default Unhappy roadster...
I need some advice. I recently replaced the CPS sensor with a non Bosh unit which seems to work fine... Two weeks later, the car is acting up again but differently than with the CPS problems. Under hard acceleration the engine seems to sputter (usually at the top of 1st) and today (while hot rodding) the engine stalled and almost put my face through the windshield. The check engine light came on and I barely made it into the parking lot at my work as I coasted in. No limp mode, it just shut down. I let it sit for an hour and it started right up with the check engine light on. 8 Hours later and no OBD2 scanner with me, I started the car and to my surprise the check engine light was off and the car ran fine. My drive home (30 miles) was fine but I babied it the whole way. No codes with scanner when I plugged it in that night? Very frustrating.
My suspicion is two different things. Either I bought a crap CPS sensor (direct import brand with a life time warrantee) OR the fuel pump is going out, maybe a bad fuel filter or both? Would anyone like to help with any ideas of what to do next? I can do this work myself, just need to be pointed in the right direction as I have been, numerous times on this forum. Based on the looks of my dirty tail pipes, I do not believe the car is running lean, but I am not an expert. Again all my problems are under hard acceleration.
I have added some mods this year, DCAI, 65mm pulley, EC tune, new plugs & wires and an oil catch can. The car is now just above 60K miles.
I would appreciate any help. Thank you!
Old Dec 19, 2013 | 09:25 AM
Default Re: Unhappy roadster....
Dirty tail pipes, your car is running rich, which is a lot better than lien. I don't think any one on here has had any luck with other CPS's other than Bosch. It could be that, it could be the RCM with the solder joints. I have had the one car run rough, but didn't die, and it was the CPS. It was hard to start as well. That is where I would start. It isn't fuel, or it would continue to cause a problem, especially since the engine code went away.
Old Dec 19, 2013 | 12:47 PM
firstshadow's Avatar
Get an oem bosch cps in there first before anything else
Old Dec 19, 2013 | 01:16 PM
I'll take a stab at this and say it could be low fuel pressure due to the fuel filter pressure regulator being faulty.
Old Dec 19, 2013 | 01:24 PM
sk8erjosh09's Avatar
I have a brand new Bosch OEM crank sensor if you want to try that first?
What does the pump sound like when you turn the ignition on?
Old Dec 22, 2013 | 11:24 AM
Tp'sfury's Avatar
Last night the check engine light came on after the car stalled at a red light. I was able to re-start the car, get it home and check the code. Looks like the CPS was the culprit again. I will use the Bosch sensor this time as I should have the first. Thanks for your replies, I appreciate it!!!
Old Dec 22, 2013 | 11:30 AM
itsky's Avatar
I'm glad that you figured it out. Sometimes it is worth paying a few more $$$ for the right part. Hopefully this will be the last one that you need to replace.
Kodebuster
Jul 18, 2014 02:28 PM
Kodebuster
Sep 2, 2011 12:53 PM
suicidedoors.com
Jul 9, 2009 04:26 PM
beto7650@yahoo.com
Apr 7, 2008 07:56 AM
pachyderm
Jun 17, 2004 09:55 PM
