Help Cylinder misfire
Old Feb 13, 2015 | 01:04 PM
akakaz2's Avatar
Default Help Cylinder misfire
If anyone has any ideas please advise. It started 4 days ago with a little misfire then as car warmed up it was worse then at idle in gear it was very noticeable they it threw on the check engine light. took it to a friend mech. pulled the codes said misfire cyl. 1 so I bought a new coil pac and plugs for #1 and replaced them reset the light next day same thing started out slight miss then worse now light checked code again same misfire #1 even now when car starts up runs smooth when driving no mis only when its warm and at idle. Thank in advance I know I will get some very helpful advice. I don't post on here much but read all the time.
Old Feb 13, 2015 | 01:06 PM
Default Re: Help Cylinder misfire
Try swapping the coil to plug WIRES from another cylinder.
Old Feb 13, 2015 | 01:18 PM
mobilefitt's Avatar
check wires, make sure they are clicked in place. then switch wires, then switch plugs, then coil packs. Injectors come next/fuel pump, and then the cylinders themselves. You should find the culprit by the coil pack switch or before.
Old Feb 16, 2015 | 09:29 PM
akakaz2's Avatar
Changed #1 coil pack and plug wires with #4 seems to have fixed problem so maybe it's the plug wires
Old Mar 15, 2015 | 08:55 PM
akakaz2's Avatar
Changed plugs and wires thanks to Rob at needswings hopefully problem is fixed
Old Mar 15, 2015 | 11:46 PM
Sweet2002's Avatar
Sorry if I missed it but how many miles on the motor? I have a set of plugs and wires from Rob sitting here but removing a steel threaded plug from an aluminum head after being in there for what is likely 14 years is somewhat disconcerting. Knowing my luck I will remove most of the threads on at least one of those plugs! I have to assume no problems? I bought mine simply since I believe mine have been installed since new as I bought the car last fall with 72k miles on it so assume they are the originals. Glad it worked out for you. I have a couple of small, very small bucks at idle that I hope are removed once the new tune parts are installed! Mark
Old Mar 16, 2015 | 03:39 PM
akakaz2's Avatar
I have 80000 miles on it now plugs were a little stuborn but came out took about 3 hours.
atdavis2
Sep 21, 2015 01:25 PM
getshawty
Aug 24, 2015 10:30 AM
rmcdaniel12
Aug 7, 2015 01:37 PM
Bayukbros
Jul 17, 2015 04:22 PM
