F=m.a Acceleration Chart
Old May 6, 2015 | 03:36 PM
Billy22Bob's Avatar
Default F=m.a Acceleration Chart
Cant resist my calcs.
Wanted to see the effect on acceleration times if I;
...a) upped the torque (65mm pulley) and
...b) changed to a 3.27 diff.
I've gone simple here and assumed a constant torque curve...this is a little bit of a stretch in 1st, but probably ok for the others given the small power band they operate within.
This uses kerb weight plus driver and
SLK32 rear wheel dimensions 17/245/40 = 1972mm circumference and 636mm diameter
....For the SRT6 19/255/35 = 2077mm circumference and 661mm diameter.
Interestingly enough - these larger wheels extend the SRT6 times out by 0.33 seconds over the SLK32 due to the 4% torque reduction at the wheels....
If I've made an y errors or you think this is absolute crap - I'm sure you'll let me know.....
oh...BTW the other reason I was doing this was to work out how a 790Nm SLK55 Kleemann (1650kg - 3650lb) monster could actually get power to the road....
L8tr - slight change to the calc sheets and added SRT6 v SLK32 for the different wheel diameters.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 6, 2015 | 04:21 PM
Billy22Bob's Avatar
Default Re: F=m.a Acceleration Chart
updated sheets for SLK32 and SRT6 wheel diamters
I've used a couple of fudge factors (1.0s and 2.4s) to try and best match the times observed in real life. This would be for reaction times and gear changes etc.
Old May 6, 2015 | 05:03 PM
If I've made a yn errors or you think this is absolute crap - I'm sure you'll let me know.....
I am pretty good at this finding fault thingy, I spotted typo, spelling and capitals missing errors. As to the calculations I haven't a clue.
Old May 7, 2015 | 11:05 PM
He he he he he he he
Old May 8, 2015 | 09:41 AM
Padgett's Avatar
Good basic thinking and ok for an automagc but with a stick shift you have to consider things like wheel spin caused by excessive torque at the wheel.
Any time you have a light car with a big engine this becomes a factor.particularly if a traction control is dialing back on power.
Old May 8, 2015 | 12:53 PM
dinasrt's Avatar
I think that Einstein wasn't good at grammar as well. But I don't think he was O.C.D. either.
Danyuhl
Nov 2, 2019 05:18 PM
bbsrt6
Feb 16, 2019 12:39 PM
velociabstract
15
Sep 7, 2015 03:43 PM
Just1n
Aug 8, 2015 11:45 PM
waldig
Jul 20, 2015 08:10 AM
