Ignition switch ?
Key will not trun the ignition witch it started 2 days a go when I took out my key from Ignition switch it would ding like my head lights where still on so l had to put the key back in and move it on to off again and then it was fine ... Now I just got in my car and key will not move in any way and I'm about 80 miles from home is there any thing I can do out here to get the car home and than anyone have a idea how to fix????
Re: Ignition switch ?
Originally Posted by fastfred
(Post 848702)
Originally Posted by pioneer4x4
(Post 848704)
Search on "Sticky Key" There are many threads about it. Personally I don't have the issue (yet). Try to keep jiggling the steering wheel while trying the key.
(Post 848709)
Thank you yes I have tried re-setting battery and moving the steering wheel and the key will NOT turn even a little bit it's stuck in the off position ....
Read this set of instructions to fix the problem. CLICK |
(Post 848704)
Thank you for your input so far and I have read a few DIYs and my problems being it will not turn at all and most of the Fixs I have read so far you have to turn key to 1st position ... Anyone... how can I fix it with out turning the key??? I'm out here with my dash all on the floor ....THANK YOU!!
If you can't turn the key at all, you have got to drill the pin out. Not fun.
We preach and preach at people: Fix this before you have an issue! Now, when mine locked up, I had the car towed home and by the time I got it home, it turned. IF you get it to turn, DO NOT REMOVE THE KEY UNTIL YOU FIX IT. Removing the key is what sends the cam into place and that is where it locks up. |
(Post 848732)
When you gonna pre-emptively fix yours, Klay?
(Post 848732)
It tells you what to do if the key does not turn. You have to read the posts properly to get answers. |
(Post 848739)
and I'm hoping to help a friend do his before too long. The hours at the ice cream shop are tapering off so he should have time. |
I have to wonder.. is the "stuck" key really stuck. I loaned my daughter my coupe. It's had sticky key for four years now. She was shown the "magic flip" that works just fine with it. (I would compare it to snapping your finger). She spent an hour one morning before calling me.. "is the steering wheel lock holding it".. She went out to try again and 2 minutes later was on the road - with no issues the rest of the week she had it.
Originally Posted by Mrmiata
(Post 848760)
And PS: thats why remote internet troubleshooting can be difficult....... |
Originally Posted by KDW4Him
(Post 848765)
Agreed, I have discerned there are posts where the tension on the steering wheel is the culprit AND there are posts where the mechanism is really locked up.
I'd my car towed home with some extra work with my steering weel locked and trans stuck in park anyway today I took the dash apart and on Saturday I'm going to drill out that little silver pin .. I'm not sure what that will do. And I'm keeping my old ignition and I'm not sure what I have to do to it??? The DIY says to take it out ...also just wanted to say the tow truck driver tried everything he could to get it unlocked and no deal ....so it's not sticky it's locked up....
(Post 848846)
The How To explains how to get the locked key out, read it again. |
(Post 848857)
The transmission can have the shifter moved out of park by poking a screwdriver or something similar down the back of the shifter slot. It is advisable to read the Owners Manual sometimes.
1 Attachment(s)
I have been drilling on this pin on the shaft by the clamp for over an hour now and not getting munch but a mess where the drill keeps falling off the pin head .. Pleas any input thank you ...
(Post 848901)
1 Attachment(s)
Thank you but I can't afford a dermal in the DIY he says you can use a drill and ,I'm on a fixed income so anyway I have been drilling on this pin for about 3 hours and not munch has been done other than its making a mess out of the area around the pin ... It's my understanding that I have to drill or dermal it out as my key will not go in the 1st position so I can get the ingition out to open it up to take another pin and spring out of it and than my key will work???
