Additional heat exchanger
Old Nov 1, 2015 | 04:25 PM
Wolf_7's Avatar
Default Additional heat exchanger
Hello,i install 62 mm pulley after 65 and my iat s run hoter,65c in fourth gear,i have stock e55heat exchanger and can install it in front of stock cooler,have bosch 010 pump and i have question will the pump handle 2 heat exchangers and drop iat? Or water pressure will drop and there will be no effect ?ps i want to know what fuel mods i must do on 62pulley,thanks
Old Nov 1, 2015 | 07:29 PM
velociabstract's Avatar
Default Re: Additional heat exchanger
A stock E55 heat exchanger is longer, deeper, shorter, double the capacity and there's not enough space for it in front of the stock H/E. With some modifications you can fit it in place of the stock one. I can't say if the stock pump is enough for dual heat exchangers if you find a way to get 2 in there.
Les
Old Nov 1, 2015 | 07:37 PM
chuK_138's Avatar
You're going to need an SL55 fuel pump and 550cc injectors to feed that and an appropriate tune.
Old Nov 1, 2015 | 09:58 PM
Sweet2002's Avatar
Wolf, the 62 is very near my 178/70 combo and I went with the SL55 pump, free flow filter and adjustable regulator. Then added a set of Bosch 550 cc inj's. Costly for an additional 2 psi of boost!
Old Nov 2, 2015 | 02:22 AM
Wolf_7's Avatar
on slk s there is room in front of stock cooler with some modifying room,so i will try 2 coolers and show iat tests
on 62 mm and d cai my boost is 18.5 psi and i dont notice any fueling problems, maby the boost is low for 62 mm?
Old Nov 4, 2015 | 12:53 AM
Zoodust's Avatar
You will have to have 550 injectors, 55 fuel pump, upgraded IC pump, and if possible a killer chiller kit to help those IATs..
Power Sedan
Nov 8, 2015 01:52 PM
BlueFire
Oct 22, 2015 05:27 PM
RyanB
Oct 13, 2015 09:20 PM
cdcrone123
Oct 11, 2015 10:54 AM
ATX SRT-6
Oct 5, 2015 03:57 PM
