Spark plugs for more boost
Old Dec 2, 2015 | 09:55 AM
Wolf_7's Avatar
Default Spark plugs for more boost
Hello there ,i have 1'3bar boost19 psi , and its time to change plugs ,is oem replacement ngk plugs good for me or try bkr7eix-11?is anyone run on eix11 s?
Old Dec 2, 2015 | 10:52 AM
NeedsWings's Avatar
Default Re: Spark plugs for more boost
I run/recommend the ifr6d10's on the compressor motors
Old Dec 2, 2015 | 01:01 PM
boostmonkey's Avatar
Default
I run the NGK BKR7EIX-11 spark plugs. They work great for me. I am running 21 psi of boost.
Old Dec 2, 2015 | 01:45 PM
Wolf_7's Avatar
boostmonkey, did you change gap size? and what size is best for high boost?
Old Dec 2, 2015 | 07:26 PM
Guran's Avatar
NGK R5671A-7
Racing spark plug
25.1 psi, third gear
Old Dec 3, 2015 | 03:03 PM
Default
No, the plugs are all gapped between .040 to .041. .040 is the stock specification IIRC.
Old Dec 3, 2015 | 04:34 PM
Wolf_7's Avatar
i think 40 gap iis not good, there is bkr7eix ix sparks its same but with 031 gap(08) maby on this will better?
Old Dec 4, 2015 | 06:08 PM
Default
I have not had any misfire problems at .040 gap. The coils seem to be able to still handle the stock gap at 21 psi.
Old Dec 4, 2015 | 06:11 PM
Default
Originally Posted by Guran
NGK R5671A-7
Racing spark plug
Non-resistor, nickel center electrode? I'm glad it works, but with the short life span and possible emf interference, it may not be for everybody.
Old Dec 5, 2015 | 12:15 PM
velociabstract's Avatar
I experimented with different gaps on the stock plugs. No positive difference detected. Currently I'm back to stock heat range with stock gap and still running like a scalded (insert fast animal). I don't think changing the heat range or gap is needed unless your boosting over 20 psi.
Les
Old Dec 5, 2015 | 01:52 PM
Wolf_7's Avatar
thanks my friends for posts, it realy helps me now i will buy ifr6d10 , im in georgia near russia, here is ngk sellers but i think its china ngk, on ebay or amazon you have some trusted seller?
Old Dec 5, 2015 | 02:27 PM
syfi's Avatar
https://europortparts.com/catalog/pr...view/id/250751
Old Dec 5, 2015 | 05:19 PM
Guran's Avatar
Smile Re: Spark plugs for more boost
I am leaving this forum. Sorry
Old Dec 7, 2015 | 01:54 PM
tunaglove's Avatar
Please don't, I always check your posts!
treyleblanc
Nov 7, 2017 01:18 PM
spoiler
Dec 22, 2016 06:39 PM
Blackktieguy
Nov 26, 2015 02:29 PM
pioneer4x4
Nov 13, 2015 03:30 PM
onehundred80
Nov 2, 2015 09:55 AM
