Telescoping steering wheel
Old Feb 23, 2018 | 10:09 PM
dodgemahal's Avatar
Default Telescoping steering wheel
Does the telescoping steering wheel function only work when the key is turned to "on" or the engine is running? I have the batt disconnected and I can not get it to telescope in or out.
Old Feb 23, 2018 | 10:40 PM
Default Re: Telescoping steering wheel
Did you pull out the lock?
Old Feb 23, 2018 | 11:11 PM
dodgemahal's Avatar
Sure did. Can you answer my question? Thanks.
Old Feb 24, 2018 | 12:02 AM
It telescopes with the key out and/or the battery disconnected, it even telescopes when you are driving.
Old Feb 24, 2018 | 09:53 AM
dodgemahal's Avatar
Thanks 180. Must be stuck somehow.
Old Feb 26, 2018 | 03:42 PM
srs244's Avatar
for what it's owrth, when i first bought my srt6 convertible i thought mine didn't even have that option. i was a bit afraid to really give it a good tug, but i needed to have the cruise stalk/switch replace and the folks that did it also tried to make it telescope, but they eventually applied a good enough tug and it broke free (with me watching of course). i'm guessing yours is just a bit difficult from lack of use. it should function (as already mentioned) regardless of battery or key (i've tried it while moving and it does in fact event work that way, although if everything works correctly you will get a warning lamp on the dash.
Old Nov 9, 2022 | 04:24 PM
rehclem's Avatar
I will try the telescope function
jqm
gekkoski
Aug 9, 2022 09:57 AM
Penniman
Feb 25, 2018 12:34 PM
FUBU
Sep 5, 2012 08:42 PM
X-Feuer
Jun 30, 2012 03:47 PM
blackcrossfire07
Sep 8, 2009 02:00 PM
