Just bought an SRT6 Coupe...but have a door lock issue
Hi- I just bought an SRT6 and a couple days later the key fob and interior button for the locks stopped working. The hazards just flash, but nothing happens. When I hit the button on the inside I hear the pump in the trunk kick on and a hissing noise from the passenger door. Im assuming I am going to be taking the door apart? |
Re: Just bought an SRT6 Coupe....but have a door lock issue
Originally Posted by k_2yle
(Post 912150)
Hi- I just bought an SRT6 and a couple days later the key fob and interior button for the locks stopped working. The hazards just flash, but nothing happens. When I hit the button on the inside I hear the pump in the trunk kick on and a hissing noise from the passenger door. Im assuming I am going to be taking the door apart? If it is then the air hose has broken where it flexes. The easy way to do that is splice a new urethane hose to the old hose replacing the area that flexes each time the door opens.The old hose is 5 mm outside diameter. So a 5 mm inside diameter hose could be used to repair it. The old hose is bound up in the wiring loom, leave the old hose in place between the splices to make things simpler. Wrap the new hose to the wire loom to keep it in place. |
The noise seem to be coming from the actual door latch. Is it one continuous system? Would one door stop both from working? Also I notice the window came down a little bit on the same door. I assuming the issue is connected. Appreciate everyone's help and advice.
