Part numbers
Old Jul 2, 2019 | 12:57 PM
COJAG's Avatar
Default Part numbers
Does anybody know the part numbers on our SRT for the supercharger pulley, mine is starting to make a racket and am trying to get a replacement. Originally thought water pump was going but now think bearing in supercharger pulley making the noise. If anybody knows of part number, either mercedes or chrysler that would be great or is there an aftermarket place too get this part. Thanks not having much luck up here in Seattle with mercedes dealership, chrysler dealership no help. Any help would be great on numbers or where to find for this problem. Thanks
Old Jul 2, 2019 | 01:56 PM
NeedsWings's Avatar
Default Re: Part numbers
a replacement pulley is very expensive, you most likely just need a new bearing and to change out the sc oil.
Old Jul 2, 2019 | 03:46 PM
eBay has them, there are two in this search. CLICK
You can go to a bearing shop, and buy them if you like as it is a common bearing. Here are the part number and specifications.
OEM SC pulley bearing. 32mm(ID) x 55mm(OD) x 23mm(thick). NSK #32BD45DU or 32BD45DUM, available at BearingSource for $15.40 or Nachi #32BG05S1- 2DST Available at bearingsdirect.com for $20.49 and
Amazon
at $28.53
Prices will be out asa the list is old.
NeedsWing also sells them.
SilverFox
Dec 3, 2007 01:19 PM
dynamicS
Aug 1, 2006 09:57 PM
brittt1
Sep 21, 2005 04:51 PM
xfireguy
Feb 21, 2005 02:32 PM
Sunny9850
May 19, 2004 09:01 PM
