Oil light come on periodicaly
On my 2005 SRT-6 sometime oil light in dashboard show up. and after couple of minutes came off.
Oil level on deep stick is o.k. I try to pay attention when it happen. Most of the time it appear after a run (motor warmed up) (Or pushed a little bit hard) Stop (motor off) for a little period and start again to drive (at this time oil light came on) But after a minute or two light disapear. Could it be cause by the temperature of the motor? Like i noticed in a previous post, it seem to me that motor need long time to cool down even if it is shut off. |
Re: Oil light come on periodicaly
Did you check for any codes?
I don't check for code. Maybe i should buy OBD II code reader or is it other way to read codes. Like it was possible to do with ancient OBD I
Take it to Advance Auto Parts and they read it for you.
https://cimg6.ibsrv.net/gimg/www.cro...f49fe1228a.jpg
On my other Chrysler ( Concorde Limited ), I don't need a code reader. Just turn the ignition on/off 3 times, then on, codes show in the odometer window. |
Oil levels (too high or too low) will not set codes. Check engine oil level, if it is OK, then you have the all-too-common oil level sensor failure.
It will cost around $125 for the part. https://shop.advanceautoparts.com/fi...l-level-sensor Labor will be way more, I'm afraid, if you don't do it yourself. |
(Post 926312)
I think my favourite reader is my $99 BlueDriver, I have four. It is handy as it is cordless and works on my iPad. It specifies what feature in the emissions system requires to be reset. |
Mine has only ever shown but one code, P0440 - emmissions
Maybe some day I'll fix it, I just keep resetting it - good for a month or two. |
