Crossfire SRT6 Throttle Body Weird Noise
Old Jun 13, 2020 | 08:21 PM
305overview's Avatar
Default Crossfire SRT6 Throttle Body Weird Noise
Hi everyone, I got a 2005 xfire SRT6 with following issue, maybe can be 2 separate problems, but the following is the one I need to make clear In order to ask the second issue.
When I turn on the key before start engine the butterfly into the throttle body makes a klick “it looks is a normal sequence in different cars” but in my after 30 seconds the butterfly makes another weird adjustment, like another three klicks.
That’s my concern, is this normal plus you can hear a continuous “beeeeee” noise coming from the throttle body itself.
here is a video on youtube with the complete sequence.
Any help it will appreciate.
Thanks everybody..
Old Jun 13, 2020 | 10:09 PM
Default Re: Crossfire SRT6 Throttle Body Weird Noise
https://youtu.be/MnELRh0ofRY
Thanks everybody..
I have NEVER seen anything like this before. I'm actually stuck on suggesting anything but trying a different TB. IF the second does the same thing, I have no other suggestions. Just to be sure, no one was touching the pedal or anything else in the car right? Sorry that's all I can suggest, but I am sure someone else here will chime in to help. All the posts I read since becoming a member, never heard this issue. Good luck!
Old Jun 13, 2020 | 11:09 PM
Already try a second Throttle and still the same issue. That’s why my doubts about is this. is normal or something else is causing the issue
Old Jun 14, 2020 | 08:37 AM
velociabstract's Avatar
My best guess is something to do with the fly by wire. I'm unfamiliar with where the TB signal sender is housed (throttle pedal?) but I'd take a look at it.
Good luck
Les
Old Jun 14, 2020 | 05:21 PM
You never mentioned a second TB... Next, I agree with Les, makes sense since the pedal IS an integral part of the circuit. It also has the potential for being stomped/abused in its past life. Good luck!
Old Jun 14, 2020 | 05:30 PM
philosophico's Avatar
Normal, just went to my car and it did the same thing. I have a srt-6.
king happy
Feb 12, 2019 11:27 AM
awesome1
Mar 18, 2017 01:02 PM
josh armstrong
Jun 25, 2015 08:42 AM
onehundred80
Aug 14, 2011 06:21 PM
Danno
Jun 1, 2006 06:12 PM
