Spark plugs
Old Nov 10, 2020 | 07:28 PM
fastfred's Avatar
Default Spark plugs
It seems like my spark plugs are welded in I can’t brake them loose I tried soaking them for days and a breaker bar but it feels like if I keep up they are going to strip out ... any help please?
Old Nov 10, 2020 | 07:50 PM
dcskmail's Avatar
Default Re: Spark plugs
Are you using liquid wrench ? maybe an impact wrench set at low torque
Old Nov 10, 2020 | 08:39 PM
How many miles and what year is you Crossfire ??
I've heard that the plugs can become almost impossible to remove at or over 100,000 miles
Old Nov 10, 2020 | 08:55 PM
lotsofspareparts's Avatar
The original..... like OEM plugs with nothing but the Benz logo on them are still installed in the 181k mile 3.2 I pulled out of my V8 car.
I pulled a few of them out a few weeks ago and it took quite the effort. Even with the effort, I really didn't expect them to be the factory plugs because the engine ran so good.
I would really twist on them, but your car is not my car.
Good luck.
Jared
Old Nov 10, 2020 | 10:24 PM
VintageBikesUSA's Avatar
In our houseboats we would run MMO in the fuel a week ahead of time and then again spray each plug the night before doing the plug change. it worked.
Old Nov 10, 2020 | 11:16 PM
fastfred's Avatar
2005 and 138k I have had the car sence 2010 and never changed the plugs
Old Nov 11, 2020 | 09:49 AM
NeedsWings's Avatar
run the car to warm up the motor, then shut it off and try again
Old Nov 14, 2020 | 08:36 AM
Also hitting it with a impact worked on a car I had, if you can use one that is. the car i used it on was a 2.2 inline four so the plugs were easy to get to.
Old Nov 14, 2020 | 06:22 PM
fastfred's Avatar
Well I have tried heating up the engine and lightly hitting them and tighten and losses... they are stuck in there can’t even get one out ....Dammm!!!
Old Nov 14, 2020 | 06:38 PM
It may help to remove the valve covers to give you better access?
Old Nov 14, 2020 | 06:59 PM
fastfred's Avatar
Yea that’s what I was thinking also 👍
Old Nov 14, 2020 | 07:09 PM
Yes, it is well worth the effort to remove the valve covers when doing plugs.
Old Nov 16, 2020 | 12:39 AM
crosseyed-crossfire's Avatar
soak'em with plenty penetrating oil, tighten first n then loosen, patience is the key and soak the s-it out of em
Old Dec 29, 2020 | 09:01 PM
fastfred's Avatar
Thank you all for the help !!! Well it’s been a battle and doing everything I could do working on and off for over a month and I have gotten 8 out so far sooo I’m breaking down and it’s going to the shop !!!
Old Jul 2, 2021 | 08:50 PM
fastfred's Avatar
well the dealer I took it to told me I need new heads put in …. I went to a few other shops but no luck no one wants to touch it till I find German auto repair in Placerville California they had the car for 6 weeks but they did do it changed all plugs and now my SRT -6 is running great and it only took a little over 6 months…..LOL
Old Jul 3, 2021 | 07:43 AM
So now we should call you fasterfred?👍
Old Jul 3, 2021 | 11:35 AM
fastfred's Avatar
funny but yea it runs so much better with the factory plugs gone they where in there from 2005 till 2021 and 139 k miles on them …LOL
Old Jul 3, 2021 | 02:52 PM
They probably had gaps you could drive a bus through, definitely time for a change.
I should loosen mine and retighten them, I do not want them to seize up in place.
djohn14296
Mar 30, 2017 06:31 PM
grandpamike
Mar 29, 2017 06:28 AM
XfireBlake
Nov 17, 2010 03:29 AM
yanni2112
Feb 14, 2008 06:48 PM
roms33
Nov 18, 2004 12:02 AM
