true dual or cat back?
Old Jan 10, 2008 | 10:38 PM
tylerxfire's Avatar
Default true dual or cat back?
k all beef spuashed between ther members please, opinions wanted!!, so should i go with a local exhaust shop and run 2.5 true dual pipes into a x pipe and then back into magnaflow muffler or some other muffler once again opinions wanted, or just buy the magnaflow cat-back or borla cat-back, i want to be heard but not obnoxious, i would prefer a little on the loud side though with a nice tone not really raspy just clean sound, i do want to add power but i guess am not too concerned with a huge gain from the exhaust a little top end gain would be nice with no loss of torque thats y i am leaning toward true dual with x pipe, but let me know what you think, i really would like to hear a borla clip and magnafow cat back driving and not just revving
Old Jan 11, 2008 | 11:58 AM
ToplessXFire's Avatar
Default Re: true dual or cat back?
no Complaints With My Magnaflow An Its Stainless Steel.
Old Jan 11, 2008 | 12:12 PM
tylerxfire's Avatar
how loud is it though, compare it to something honestly so i can get an idea, also do you have cats on your ehaust. and correct me if i am wrong, this system probably uses the first set of cats then goes into a y pipe then a 2.5 inch single straight pipe back, then i don't know if it uses another cat or resonator before the magnaflow muffler, sorry if i confused you how does this system come again, and if you removed any cats or not.
Old Jan 11, 2008 | 12:28 PM
tyler PM Sent
Old Jan 11, 2008 | 12:56 PM
Opticon's Avatar
Duals will flow better @ high RPM and the X pipe will remove some of that rasp. Run them both through a muffler with a deep tone (like a Dynomax Ultraflo) and it should come out deep and mellow.
You can probably save yourself some labor, spacing, and material costs by purchasing the Ultra Flo X (duals cross inside the muffler itself).
This is my Plan C. That is, if I exhaust (LOL) plans A and B and I'm still not happy.
Old Jan 11, 2008 | 02:00 PM
tylerxfire's Avatar
and keep stock cats?, because nobody will fabricate the exhaust and delete the rear cats, i plan to try it out with them then if im not happy replace them with just straight pipe welded in place of the stock rear cats, also you don't recommend magnaflow muffler?
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 30, 2015 07:39 PM
waldig
Jul 29, 2015 06:54 AM
waldig
Jul 20, 2015 08:10 AM
