CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Engine, Exhaust, Transmission and Differential (https://www.crossfireforum.org/forum/engine-exhaust-transmission-differential/)
-   -   Iridium Plugs whose got'em (https://www.crossfireforum.org/forum/engine-exhaust-transmission-differential/30905-iridium-plugs-whose-gotem.html)
Stogey Jan 9, 2009 10:17 AM
Wanted to get some feedback if you're one who purchased Iridium Plugs for your XFire. How bout some opinions, Good, Bad, Not worth the price, big difference in performance, gas mileage....etc. Let's hear from ya ! :D
distantpulse Jan 9, 2009 11:14 AM
Re: Iridium Plugs whose got'em
I do. They seemed to smooth out my idle a bit. I can't say they produced any more power, but my car does run well with them.
BrianBrave Jan 9, 2009 12:08 PM
I have the NGK BKR7E-11 Iridium plugs installed. I called NGK tech support hotline and told them the modifications I was installing and these were the plugs they recommended.
So far they've worked great - I pulled one after 10,000 miles for inspection and it was burning clean......
Here's a great read from the NGK website.
http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
TVT_DESIGN Jan 9, 2009 12:36 PM
We install them on all the cars we work on as the factory ones are not the best for performance. Much better idle and throttle response, nothing substantial as far as power is concerned.
Wedge Jan 9, 2009 12:57 PM
Which iridium's would you use for a non-modded car?
Sodamhot Jan 12, 2009 05:16 PM
I run the zex plugs 2 degrees colder. Not a noticable difference but Nitrous and platinum dont mix.
oledoc2u Jan 12, 2009 05:26 PM
thanks Brian, time for new plugs while I have the motor down...
Mimi05SRT6 Jan 13, 2009 01:37 AM
After doing the mods to my car, I re-gapped the stockers to .034 and the car runs great. I don't see where buying different plugs does any good. :cool:
spensley Jan 13, 2009 05:40 AM
I have them, and no complaints.
Smoother idle etc.
Look at TVT's website for plugs and recommendations.
murtazanooruddin Mar 2, 2009 10:01 AM
NGK's iridium plugs give misfire changed all 12 but not designed for it you have to use the mercedes benz ones which are bosch from the dealer run about 21 buks each dont get iridium waste of money!
70GT6 Mar 2, 2009 01:35 PM
NGK Iridiums smoothed out idle - no issues at all.
I would use them again in a heartbeat.
NGK IX IR's are far superior to stock plugs.
MikeR Mar 2, 2009 04:51 PM
I have the NGK Iridium's also...one stage colder...they work fine and I have no misfires...
MikeR
© 2026 MH Sub I, LLC dba Internet Brands
