Throttle Body on ebay - 380091078883
Old May 11, 2009 | 09:03 PM
spensley's Avatar
Default Throttle Body on ebay - 380091078883
There is a crossfire throttle body on ebay - I know that there is a shortage of these so if anybody is looking for one to bore out and make a 74mm...
Item # 380091078883
Old May 11, 2009 | 11:40 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Throttle Body on ebay - 380091078883
There's no shortage of 68mm TBs. They are all over for 120.00.
Old May 12, 2009 | 07:56 AM
spensley's Avatar
What's the maximum you can bore a stock 68mm t-body out to? (70mm?)
Old May 12, 2009 | 08:58 AM
Trying to save TVT some time so he can get that 300 kit on the dyno so I will attempt to answer based on what I have previously read....
The 68mm stock TB can be bored to 74mm MAX
Please correct me if I am wrong....
Old May 12, 2009 | 01:06 PM
spensley's Avatar
That's the impression I was under, but when TVT said there were plenty of stock t-body's around I was wondering why they weren't being snapped up and bored out to 74mm.
Old May 12, 2009 | 01:29 PM
If I understand correctly, the MB TB that TVT is using is a much more stout piece of hardware, built to handle 400-500 HP with beefier internals. I believe this is the way many were wanting to go, but I certainly would not mind a bored stock XF TB if it will hold up the same, obviously the same flow....
Old May 12, 2009 | 01:38 PM
ACRucrazy's Avatar
How does a TB need to be beefed up wtih internals?
Old May 13, 2009 | 08:06 AM
What I mean was that if you are starting with a more stout (thicker, possibly heat treated) TB versus going with one that is designed for less power (our stock TB) and then bore out the hole, you are losing even more structural integrity. You may still be well within OEM specs once bored to 74mm, but I do not know, I was simply raising a question hopefully someone else can answer???
Would there be any significant differences between going with a stock TB bored out versus the larger MB TB???
Old May 13, 2009 | 09:57 AM
spensley's Avatar
I don't believe there would be any performance difference (or at least noticeable) as long as they are the same bore diameter. However, you raise an interesting point about the structural integrity of the part - if this was suspension or a moving item I would be concerned, but seeing as though it doesn't really move or have many forces applied to it I wouldn't be concerned. Seeing as though both throttle bodies (68 + 74mm) will fit onto the same air intake tubes (which is before the butterfly - so the initial intake is the same size) there may just be far more material on the stock 68mm which can be machined away to make it a 74mm unit. I don't have a throttle body at hand to see how they are built up/assembled so I'm assuming the above.
If you look at the pic below posted by psuperit, the butterfly is significantly less than the inside diameter of where the air-intake assembly attaches to - reitterating my assumption above.
Old May 13, 2009 | 10:14 AM
psuperti's Avatar
For sale stock TB out of my 04 with 20K. Lets see some offers ok!
blackpepper
Racing
16
Sep 27, 2015 01:38 AM
Ralph289
Sep 21, 2015 09:34 PM
ayebb
Sep 18, 2015 03:35 PM
RacerXofFL
Sep 15, 2015 05:00 PM
steps
Sep 3, 2015 07:24 PM
