Installed Johnson CM30 Pump / What triggers pumpt to come on??
Old Jul 26, 2012 | 05:45 PM
dinasrt's Avatar
Default Re: Installed Johnson CM30 Pump / What triggers pumpt to come on??
Originally Posted by RED DOG
Hello FUBU, THANKS for your contributions to this thread. Regarding the Waldig / Needswings pulley saver kit, I'm confused as to which part number pulley saver kit to order. All of my engine pulleys are stock. What is the correct Pulley Saver Kit part number for me?
What you would want, if you're staying w/ stock Crank & SC pulley, is the PSKC3. It is made for the addition of a smaller SC pulley, but works fine for a stock setup. The tensioner will accommodate the minor difference in the diameter between the stock SC pulley and a smaller SC pulley. Please double check w/ Rob @ Needswings w/ this info., as there may be a slightly larger belt than the #1153 that comes w/ the PSKC3 that may be more ideal, but I don't think so. You'll be all set if you decide to get a smaller SC pulley for more power in the future.
xfireohio
Jul 20, 2020 12:03 AM
Timesnow
Aug 15, 2015 03:03 PM
BrenLW
Aug 5, 2015 04:53 AM
Jul 29, 2015 06:13 PM
