Radiator Cooling fan not working
Help pls I have replaced the radiator cooling fan and the control module and checked the fuse. And it is still not working. I have no idea y it is not working. What happen first the fan went bad the bearings gave out. so i replaced it and nothing. then the control module and nothing found the 50 amp fuse and its fine. i dont knowif there is anything else to check. PLS help
Re: Radiator Cooling fan not working
Have you connected the new fan directly to 12v and ground to see if it works ?
( 12v to pin 2, black/dk green and ground to pin 1 brown/black ) If it runs OK, have you gone through all the "fan don't run" steps in 7.2 of the service manual ? |
First step - what amber alarm lights are on with the motor running?
If the Fan module is bad, you should have a little radiator-looking icon turned on in the left hand area of the instrument panel. If the fan simply won't run and you don't have this icon turned on, I'd suspect the PTCM is crazy. ANY issue with the FCM or a blown fuse feeding the FCM should light this indicator. If the PTCM is not turning the indicator on, I'd suspect the PTCM. |
(Post 840643)
(Post 840652)
Power Train Control Module.
It's in the box by the battery along with the RCM and BCM ( Relay Control Module & Body Control Module ) It is the board in the center. battery -> BCM -> PTCM -> RCM disconnect the battery ground lead, then disconnect and reconnect all the PTCM connectors, reconnect battery and see if this helps. |
