74mm throttle body upgrade
Alright so I have an 04 Crossfire.. automatic.. and I'm looking at upgrading the throttle body to a 74mm. Now, having said thst, I know nothing about what I need. Is there a certain kind, brand, etc? I'm assuming I can't just go buy a 74mm tb and slap it on there? Help me out.
Originally Posted by Brady517
(Post 850469)
N/a 74mm throttle body upgrade guide. The part number for the right throttle body is there, I got mine from eBay off a donor car with 33k miles for $45 shipped. |
Re: 74mm throttle body upgrade
Originally Posted by Speedy4x4
(Post 850471)
Good thread started with a walk through type in
Yes it should work, you need this also but swap the original sensor into the new maf "tube" Don't forget the new O-ring.
https://www.crossfireforum.org/forum...ade-guide.html http://www.ebay.com/itm/AIR-FLOW-SENSOR-MERCEDES-BEN-VEHICLES-VARIOUS-BRAND-NEW-/160578454125?_trksid=p2054897.l4275&rmvSB=true |
Yes, but realize that the OEM plastic IAT/MAF piece will be a restriction unless replaced with one off a model with the 74mm.
You will reuse the old sensor if the new plastic piece comes with one. Also very important to order a couple of new O rings for the TB before starting. The ideal scenario is : 74mm TB, NeedsWings CAI ( either single or dual ) and a Eurocharge tune. |
