2015 SRT 6 rough start
Re: 2015 SRT 6 rough start
Sorry did not look at this earlier but am in SW Orlando (behind Universal) and have a number of diagnostic tools.
BTW a SRT-6 shares the drivetrain with a Merc SLK32 (the AMG models drop the last digit - I also have a SLK320) and scan tools that can check an R170 (16 pin) will work on most Crossfires. (Autel Diaglink, iCarSoft MB-II)
Seems some look real hard for a bad interpretation of any statement, an attitude filtering down from your boss. It's all fake news to you.
You go on the ignore list.
I understand Matt fixed it over the phone, he advised u to change the RCM and another module ,, which fixed your car after more than 3 months and 3 shops that you towed it to one then another dealer and then another dealer and matt fixed it with a phone call. that is why i recommend him. he is good. jim barnes
You are touchy, I just said that you never asked anyone here for help and we would never know the fix. You did mention a CPS problem way back.
Seems some look real hard for a bad interpretation of any statement, an attitude filtering down from the top. You go on the ignore list.
I found a local mechanic that works on Mercedes, BMW & Crossfire vehicles. He indicated that he thinks it is indeed a fuel issue and may have to do with the fuel pump not properly priming the gas line resulting in a rough start. He said he will need to keep the car and check it when the rough start occurs as he has the equipment to do that. He already hooked up my vehicle to his scope and ruled out the cam & crank sensors that he said are working. He indicated that there are two types of fuel pumps for my vehicle. Does anyone know which fuel pump applies for my 2005 SRT 6?
Found a local mechanic that works on MB, BMW, and Xfires. He put my 2005 SRT 6 on a scope and ruled out the cam & crank sensors that he says are working. He said it is a fuel problem and he will need to keep the vehicle and test it when the problem occurs. He believes it is the fuel pump that doesn't properly prime the fuel line before start up causing the problem. He says there are 2 different fuel pumps for this vehicle. Does anyone know which one applies for my 2005 SRT 6?
Jamerian
01-29-2018 10:35 PM
pizzaguy
Crossfire Events and Meets
263
04-09-2015 12:30 PM
rcompart
07-05-2009 08:31 PM
CFbabe
27
11-01-2006 01:36 PM
