Valve covers
I'm getting around to re-re-fixing a valve cover leak on the drivers side. I've seen posts of the covers having no gaskets but I have rubber gaskets on mine. Has anyone else encountered this?
Re: Valve covers
Originally Posted by 8ighth Wonder
(Post 915347)
Re: Valve covers
Thank you for clarifying that.
Re: Valve covers
What are the best rubber valve cover gaskets for our cars and where's a good place to get them
Re: Valve covers
You can search "2003 Mercedes SLK320" and get rather good prices.
But, I don't do that, I just order from Needswings, Rob is often not the most inexpensive, but he backs his products and seldom have I heard of issues with what he sells (fit, quality, etc.). As to the RTV, that is obtainable locally from Advance/AutoZone/etc. |
Re: Valve covers
I'm also going to do the plugs. They're worn to hell and I recently encountered so bad fuel.
Re: Valve covers
I have had multiple failure of valve cover gaskets and the breather- (are they covers?) sealant. But not for a while. Was first done under an extended warranty so the event price was $100, then 2nd failure covered under a Mopar warranty and I believe the 3rd repair was the breather covers, another $100. Im handy but not a mechanic. Someone mentioned that after sealant is applied, the engine must not heat up in order for the sealant (or was it valve covers) to set up for at least 24 hours. I have not had a failure for a while so hopefully not again. Have no idea if there is a better gasket or better sealant. There are those on the forum who would have those answers.
Re: Valve covers
(Post 915362)
Originally Posted by BisB
(Post 915363)
I'd heard of others having a hard time getting the fix to "stick", so I did it Max's way.
No shop is going to to what I describe above unless they have room to keep your car protected inside while the covers are off. Ya gotta do it yourself. :) Sit back and pretend you were qualified to do what you just did. Cause now, you are. :) https://cimg6.ibsrv.net/gimg/www.cro...f68da12078.jpg |
Re: Valve covers
(Post 915367)
Then this is a WONDERFUL time to change plugs. When you have the breathers, coil packs and valve covers off, the plugs are way easier to get to.
I"m no mechanic, but I can tell you this: I do not beleive you can get the leak fixed in such a way that it won't come back for a LONG time, unless you do it yourself. And you hinted at the reason in your post: Things take time. I'd heard of others having a hard time getting the fix to "stick", so I did it Max's way.
No shop is going to to what I describe above unless they have room to keep your car protected inside while the covers are off. Ya gotta do it yourself. :) Sit back and pretend you were qualified to do what you just did. Cause now, you are. :) Apply the RTV as per the instructions on the tube. If using new aluminum screws tighten to 4 ft.lb, do not reuse the used aluminum screws. If using steel screws there is no point in exceeding the 4 ft.lb value. |
Re: Valve covers
Today I will re-assemble the larger of the two breather covers, as it had a small oil leak that burnt on the exhaust from time to time ( nasty smell ). I did the smaller one a couple years back and it's holding firm. On
reading all of the threads on this I have come to the conclusion that its not so much the torque of the screws that stop the oil seeping, but certainly the seal of the gasket cement. To that degree all mating surfaces must be totally oil & old bits of sealant free ... immaculate. The sealant will then stick well to the surfaces. The screws just hold everything in place to where it should be, and the work of the tightening torques on the screws / bolts, isn't so much to create a good seal ( as you would expect, as say, with a paper type gasket ) but just to make sure that the screws / bolts stay where they are and don't vibrate loose. Tightening torques seem to be 10 n-m ( 7.4 ft-lb ) for the two long screws, .... & 5 - 6 n-m ( 4ft-lb ) on the little alluminium screws. Do not over tighten. |
Re: Valve covers
(Post 915371)
Some say the RTV should be the ‘Sensor Safe’ type. There is no reason to use new bolts to hold down the valve cover as these screws have not been torqued so high that their integrity is questionable. Apply the RTV as per the instructions on the tube. If using new aluminum screws tighten to 4 ft.lb, do not reuse the used aluminum screws. If using steel screws there is no point in exceeding the 4 ft.lb value. I'm in complete agreement with 180's comment above. The RTV type is somewhat disputed anongst Forum members, but success was achieved using various RTV types & brands. Getting the mating surfaces absolutely clean is the most important criteria during this repair. When I performed this leak repair on the crankcase breather covers, I used steel screws with a corrosion resistant coating.. |
