Headlamps
Originally Posted by bamp
Does anyone how much the headlamp angle should change when using the adjuster on the dashboard ?
What adjuster on the dashboard?
If you try to adjust the headlamp beam height using the long white ***** under the hood, be careful, as a small change makes a big difference.
OK, I'll bite.
Originally Posted by robby363
The Crossfires in the UK have this to adjust the headlights. I wish are XFires had it.
If one pays attention, one has a chance of learning something every day!
Thanks.
You don’t have that? I think this is pretty standard now. I first came across them in an estate (station wagon) car. They are used to ensure that the beams points down safely when the back is loaded up with heavy stuff.
Slick feature though...
Not much, they move a bit but stop long before the limit of the adjuster
Jon
Just had car into local dealer to look at headlights under warranty - fitted a venting kit to get rid if the excessive misting - clear when i left but guess wot - misted by time i got home even with lights on - looks like they will be replacing them after all.
Also got level adjuster checked - replaced switch in dash - garage says its working normally but they dont know how much lights should move and if should move on each notch of the adjuster - can anyone help / try theirs to see?
amcordo
Jun 4, 2023 12:48 AM
05roadsterguy
Jun 10, 2015 01:04 AM
Electric Messiah
Nov 28, 2007 03:12 PM
