Replacing Fog lights assembly
Old Dec 1, 2006 | 08:24 PM
Jag80's Avatar
Default Replacing Fog lights assembly
I need to take the passenger side fog lamp assembly out to fix the silver cap on the inside of the lens. Has anyone done this? Can it be put back on or do I need to buy another fog lamp?
Thanks.
Old Dec 1, 2006 | 08:45 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Replacing Fog lights assembly
you have to buy a new fog lamp assembly. sealed lens.
this happened to mine as well.
Old Dec 15, 2006 | 09:46 PM
Jag80's Avatar
FYI.Took to dealer and got replaced under warranty! Told them an upgrade had been made on lamps (they said new numbers were listed for the part) so they replaced both. No complaints here...
Old Jan 22, 2007 | 12:08 PM
Steve Hellums's Avatar
Same thing happened to me last spring, took it in and they replaced the whole assembly. I was walking by the front of my coupe yesterday and noticed the little chrome piece was laying in the bottom again. I guess I'll have to take it back in again, does any body know if there is a TSB out on these things? If so I want to get both of them replaced on my SRT6 to get the upgraded one's on the car while it's still under warranty.
Old Jan 22, 2007 | 01:31 PM
MMZ_TimeLord's Avatar
One of mine was hit by a rock and broke the thick glass lens. Not covered by warranty, so I ordered two new ones so they would match.
Had no problem replacing them... just don't follow the service manual.
Use the small access door inside the fender well and you can reach all three of the allen screws. Then just remove the assembly through the little access door. Easy way is to remove the front wheel and have it turned out (i.e.- turn the wheel to full lock toward the side of the car you are working on).
I'm not sure why the service manual wants you to disassemble part of the front of the car when the access door leaves plenty of room with the front wheel off. I suspect it was because they don't want the hassle of having a customer come back to 'retorque' the lug bolts after 50 and 100 miles.
Hope that helps... Cheers!
Old Feb 25, 2008 | 08:02 AM
vsolano's Avatar
How much the lights cost? I need to buy one
Old Feb 25, 2008 | 09:01 AM
apkano's Avatar
Life is random...so am I.
http://www.chryslerpartsdirect.com/
$103.00 each.
Old Feb 25, 2008 | 09:24 AM
Choppers07's Avatar
Try www.parts.com the last time I checked (about 4 weeks ago) it was approx. $73.00 plus shipping.
Adrian_X
Nov 9, 2017 08:49 AM
jgreen
106
Sep 18, 2017 11:46 PM
axnguyen
Jul 21, 2015 11:41 AM
Mark McKay
Jul 17, 2015 01:18 PM
KwehCat
Jul 16, 2015 04:48 PM
